How di i change the bulb - Televison & Video
    Brigadier General:
  • 8,909 Answers
A flat panel TV or LCD TV has numorous lamps. It is more likely the ignitor/ballast unit that is at fault.
The lamps are flourescent and built into the display. The ballast unit is a separate board, depending on make and model.
Plasma Flat Screen TV's don't have a bulb.
I cannot suggest anything else until I know what make and model you have, plus the age.
Hope that helps
Posted on Nov 09, 2010
How di I replace the brake light bulb on a 2208 Honda accord
Wow, Did you come back from the future? I'm guessing you mean a 2008 Accord.
Remove the Brake/Signal Lens assembly, Twist and remove the socket then Pull out old bulb, push in new one.
Mar 07, 2015 | Honda Accord Cars & Trucks
How do I replace the light in my microwave?
Many microwaves require disassembly of the outer case to reach the bulb. it may not be worth the effort.
Dec 11, 2014 | In Microwave Ovens
Have 2001 Cavalier, everything works on the back except the brake lights. The center lights still works, though. Have replaced the bulbs and fuses with no sucess
Check for corrosion in the light sockets. Also make sure the base of the bulb is not melting around the contacts. I cleaned out the sockets with electrical contact cleaner. And when i replaced the bulbs i put Di-electric grease on the base of the bulb. So far so good
Feb 17, 2011 | 2001 Chevrolet Cavalier
When i run wisard it ask about old passworld
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-774, and DI-784.
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The username is admin and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 4 To change the administrative password, enter a new password in the Admin section.
To change the user password, enter a new password in the User section.
Step 5 Click Apply then click Continue to save the settings.
Note: If you forget your password, you can reset the unit to factory defaults.
Click here for instructions.
Nov 02, 2010 | D-Link AirPlus DI-524 Wireless Router
How di i get the tail light assembly of to change the brake light bulb on nisson versa hatchback
open the rear hatch and pull carpet away from the lens you want out,you will see four plastic thumb nuts,remove them and pull lens assembly out and replace your bulb
Jan 22, 2010 | 2007 Nissan Versa 1.8 Sl Hatchback
How to replace rear turn signal on 2005 aviator
If cover of light does not have screws, look behind it, inside. Pull back carpet, or access cover, and push in and turn light socket releasing socket and bulb. Bulb either twists to remove or pushes in. (if you have new one first. Go to parts house and just tell them what bulb is burned. you'll know if it twists, or pushes in) Before inserting bulb cover with di-electric gel. Available where you bought the bulb. makes it moisture proof and MUCH easier to remove in the future.
Jan 04, 2010 | 2004 Lincoln Aviator
How do i replace the rear tail light on my 2005 VW Jetta?
Get a set of new bulbs.
Remove lens by disconecting rotary knob retainer from the inside , remove old bulbs,
straighten spring clips in socket and aply di electric grease instal bulbs ,,,test.
Vitally
Sep 09, 2009 | 2005 Volkswagen Jetta
The silver housing where the light bulbs are located, behind the clear plastic casing lights are starting to corroad. this is causing poor light conditions during night driving. any solution?
you will have to change the sockets and when you do coat the inside of the new socket with some di electric grease. That will help keep water and moisture from intruding
Jul 24, 2009 | 1998 Honda Accord
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
