Question about Ruud UBHC Air Conditioner
Inside unit not blowing air
Inside unit not blowing the air and the unit is freezing up. noticed on inside of unit that their are 3 lights 1# furnace 2# ok 3# power. the light in middle is flashing.
    Novelist:
    Champion:
  • 230 Answers
The flashing light may be a diagnostic light. So count the sequence of flashing lights and write the number down like this example. Short(flash),Short(flash), Long(flash) Long(flash), Long(flash.
Usually on the other side of the blower compartment door there is a list of possible failures that will coincide with the number of flashes.
My guess is that the system is low on refrigerant. This has caused ice to form on the evaporator coil that is above the furnace. The ice will block the air from moving through it.
You will need an EPA certified technician to recharge the system and locate the leak. Make sure to shut off the A/C and allow it to thaw before he/she arrives to services it.
There are other possibilities but this one is probably the most common. Good Luck!
Posted on Jun 16, 2008
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
I have a heat pump and it freeze up
If you are referring to the outside unit freezing up, the issue is in the defrost cycle. The defrost cycle works something like this: The unit reverses the flow of freon causing the inside coil to blow cold air into the conditioned space and the outside coil is now working like an a/c unit, it gets warm to melt the frost/ice. The inside unit electric heat strips come on so you do not notice the cold air being blown in. The fan on the outside unit stops running to allow the coil to get good and warm.
Now the unit should go into the defrost cycle every 90 minutes or so. It should not terminate the cycle untill the coil is clear of frost. There is an "Klixon" type termostat that measures the temperature of the outside coil. This is most likely the problem. It is prematurely terminating the defrost cycle. I'd start there first.
Hope this helps, Let me know if I can be of any further help.
Dec 29, 2009 | Intertherm P3RC-030K Air Conditioner
2000 Civic stolen, air controls taken, then clutch fell off
Coincidence... in my opinion.
1. In your long drive, you may have set the a/c on "Max" or "recirculate" ... and set the fan on low. This can cause "freezing" the core inside the vehicle; this will create a lot of pressure in the compressor and the clutch will slip.
The "freeze" will cause the air to feel warmer; because the refrigerant is not circulating correctly.
2. Also, if there was oil or some other lubricant on the clutch, the clutch would slip, heat-up and fall apart.
3. The "fixed" a/c controls may have left the "vent" (non-circulating) control disconnected so that the inside core is unable to receive any "outside" warm air to keep the core from freezing... (possible)
Hope this helps ... comments anyone??
Sep 14, 2009 | 2000 Honda Civic
Outside unit will not start...while inside unit blows warm air
probably a.c. was left with out a gas,and compressor will not start and there is no cooling.
Jul 04, 2009 | Heating & Cooling
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
The unit is not cooling. have noticed ice on the line in the unit outside.
if one or few pipe may not aproblem may be the thermostat is aet to very low cool anf the fan on low speed or the thermostat is defective also if this icing is growing up means
-1 evaporator need cleaning
- 2 a smll freon leakage
May 04, 2009 | Heating & Cooling
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Fidgerdare electrtolux air conditioner
have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
Ruud UBHC Air Conditioner Logo
374 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
