Question about Dryers
Duet dryer Whirlpool
My dryer starts and heat, but then after 5 minutes, the heat cuts out and keep rolling. I have read on your site it might be Hi-Limit Thermostat  or the hermal Cut-Out (TCO). Can you please tell me the difference between them. Thank you very Much.
Cam In Montreal
  • 5,911 Answers
If thew TCO fails, the dryer will not heat at all. The TCO acts as a fuse and cannot be reset. It must be replaced. Please refer to the following link for some thorough advice on how to diagnose a dryer problems:
http://www.fixya.com/support/r385301-thorough_dryer_advice
If you still have questions, please post back and let me know. I suspect you probably have an operating thermostat problem, or high limit thermostat problem.
Posted on Jun 16, 2008
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Heating element starts to work and then shuts down after about 5 seconds
You may have a thermal limit switch going bad. These devices are in line with the element to keep the dryer from getting too hot. If one of them is defective, it will shut the voltage off to the element. If you are able to, check the thermal limits and your element, using a volt meter in the ohms setting. If the meter reads open after you hold the leads across the switch terminals, replace the device.
Feb 11, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
The control button on the Whirlpool Duet Dryer is permanently on. As a result, we are not able to start up dryer. We have unplug dryer for 5 minutes with no positive results. We have also tried holding...
Hi
Press and hold the CYCLE SIGNAL/END OF CYCLE button for 10 seconds to unlock the controls. Hope this helps...please post back for further assistance.
Daniel
Jun 11, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
My dryer a Whirlpool. will run for about 10 to 20 minutes, then cuts off. After about 10 to 20 minutes, I can start the dryer again (push start button) and it will run for another 10-20 minutes. ....This...
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Apr 30, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool duet electric dryerGEW 9200 L --no heat
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
Dec 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool LER5636EZ3 dryer won't heat
hi If it reads 0 hms yes thats te problem Thanks the appliance doc
Sep 12, 2008 | Whirlpool LER8648P Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
