Question about LG Ovens
I hv bought lg microwave oven mc-7649dw on 2nd nov,2010..bt after isuuing so many complin till date i hvnt recieved ny responce from the c.care..i hvnt received demo session..i hv sum question to ask ab the product which i intended to ask 4m one who cums 4 the demo session..m fm patna n my complain is already logged dere..patna c.cr is nt performing well in handling the complain
Induction fault e6
E6 - Defect Induction module or over temperature of coil sensor with Falcon User interface with production date before 2010
- Disconnect the appliance from the mains for 30 sec. If alarm still occurs after 1 min operation exchange induction module.
Over temperature of coil sensor with Falcon User interface with production date before 2010
- temperature sensor defect or wrong mounted.
  1. Check connector at induction module.
  2. Check the coil sensor, it should be placed even in the silicon carrier.
  3. Appliances with 3 zones, is the "Dummy" temperature sensor at the 2nd terminal mounted?
  4. Exchange coil with sensor.
  5. If above is without success, exchange induction module.
Dado
Jun 03, 2014 | AEG Ovens
I have a Oster microwave Model #OM1201EOVG that I bought from Target on December 19, 2010. It just stopped heating. No matter if it is at 100%, it will not heat up. It has only been used for heating...
You say you bought it in 2010? That was 7 years ago. If you made a typo that's ok. If the unit is still under warranty , Oster will fix it. Otherwise you'll have to locate a replacement magnetron (part that generates microwaves). You may just have a blown fuse . One is for the electronics and another one id for the hi voltage transformer inside. You'll have to take off the cover to access the fuses.
Sep 03, 2017 | Ovens
MY MICROWAVE IS NOt HEAt NY FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 17, 2011 | Ovens
LG MICROWAVE OVEN PROBLEM MICROWAVE Oven is not functioning. though it seems running.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 03, 2011 | Ovens
My microwave over works but no heat
Sorry to read about your problem, I hope this helps you out.
you could have one of the following issues
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE Ovens
My oven is not heating up to higher temps. Also the door doesn't seem to close all the way like it used to unless we push on it. The temp will get into the 300 range but not broiling.
oven door not closing::
There are a number of reasons why you may find that your oven door won't close properly, and troubleshooting oven doors is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven door not shutting properly, you should be able to identify the different problems, and also understand how to repair the door without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the door and fittings completely.
Latch is Broken This is perhaps the most common cause of the oven door not closing properly. The latch is supposed to connect to a hole in the oven itself, but sometimes the latch can become stuck, and it may also be improperly greased. If the latch is sticking, then you should try adding a drop of oil, and trying again. Other reasons for the latch not closing properly include dirt being trapped in the hole on the other side, or the latch itself being cracked and not fitting correctly into the hole. The latch can also be completely replaced if you find that you have repeated problems with it.
No heat but otherwise normal operation If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse. Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: Testing the high voltage capacitor. A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section: Testing the high voltage diode.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem. See the section: Testing the magnetron.
  • Open winding in HV transformer. See the section: Testing the high voltage transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode - see the section: Testing the high voltage diode.
  • Short or other fault in the magnetron - see the section: Testing the magnetron.
  • Short in certain portions of the HV wiring. See the section: Testing and repairing the wiring and connections.
A shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
Timer and light work but no heat, cooling fan, or turntable rotation This means the controller thinks the oven is working but the microwave generator AND motors aren't being powered. Note that these symptoms are subtly different than just having no heat and eliminates the actual components of the microwave generator from suspicion in most cases.
Hope it helps
You can pass your comment over.
And please don't forget to rate me. Thanks..
Thanks for using fixya....
Oct 28, 2010 | Thermador SMW272 Electric Double Oven
LG Microwave oven: start button not working pls guide
heatman101
z
Sep 30, 2010 | LG Ovens
Installation of lg over the range microwave oven
Installing an LG over-the-range microwave is an excellent way to save space in your kitchen. These types of microwaves are ideal for smaller kitchen areas. Although the retailer where you purchase your over-the-range microwave will likely offer installation service, rest assured that you can install the microwave on your own.
How to Install an LG Over the Range Microwave eHow
Oct 11, 2017 | Ovens
Ovens Logo
118 people viewed this question
Top LG Ovens Experts
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
pawnpower
Are you a LG Oven Expert? Answer questions, earn points and help others
