Question about Dell Inspiron E1505 Notebook
Remove password biose how i can del inspiron E1505
    Guru:
  • 832 Answers
Hello there!
A BIOS password is a protection measure that can be used to stop someone powering up a computer system or making changes in some of the computers most sensitive areas. Many big name computer manufacturers such as Dell and HP lock the customers out of this area because they don't want the customer changing anything and potentially damaging the machine (which the manufacturer may have to warranty). However, when someone like a computer technician or hardware enthusiast needs to make some hardware changes to the computer, they will need to access the BIOS. Here are some methods to bypass or remove a BIOS password.
NOTE: Do not try to guess the password on a passworded Hard Drive. 3 wrong guesses will often result in the information on the hard drive being lost forever.
How to Bypass or Remove a BIOS Password by Removing the CMOS Battery:
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Anyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 - 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto "Load BIOS Defaults" in BIOS and save the changes to fix them.
Hope it helps,
fossildude
Posted on Nov 09, 2010
Dell e1505 Hard Disk Locked, anyone know how to unlock it?
Dear k you
Enter bios setup by "F2" key and remove hard password,if this didn't help get a hiren's bootcd and choose remove password from the list.
Best Regards
Mazagange
Mar 29, 2013 | Dell Inspiron E1505 Notebook
I have a laptop dell inspiron e1505 and its lock
If you have the guest account enabled, plug in a USB and create a forgot password file on the USB, it works for all user accounts on the computer. This only works for Windows 7 (from experience)
Feb 17, 2013 | Dell Inspiron E1505 Notebook
Dell inspiron e1505 laptop need master reset code
Should this be a Bios password, you will need to have this taken into a shop, Should it be a windows password Google password recovery CD.
A windows password can be hacked, A bios password will take some time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2012 | Dell Inspiron™ E1505 PC Notebook
Haw can i clear the bios password in a dell inspiron 8100 service tag 5nppy01
one way is to remove the cmos battery inside the laptop for 15 minutes. if you take off the panels on the bottom, you should find a watch battery inside, that keeps the time and bios settings. removing the battery will reset the BIOS to factory, some BIOSes do retain the passwords though but that depends on the brand and model.
May 03, 2011 | Computers & Internet
I forgot my administrator password for my inspiron e1505
if you have another person the hase full acess to your system go under that persons name and delet your account and remake you a new one.
Jan 25, 2011 | Dell Inspiron E1505 Notebook
How to clear the cmos of dell inspiron i can't get pass the password
you have to remove your CMOS battery from motherboard & than you start your laptop,
After that
Fix it as it was & than restart your laptop your CMOS password will be removed after this procedure
thanks
Jan 04, 2011 | Dell Inspiron E1505 Notebook
Which key are they talking about when they say hit the del key
DEL is Delete. Usually found in a cluster with Insert, Home, End, Page Up and Page Down. With the Dell 6400 E1505, these are on the upper right hand side of the keyboard. (The "half" with the two rows of keys instead of 1 row of function keys.)
I hope this helps.
Cindy wells
Jul 12, 2010 | Dell Inspiron E1505 Notebook
I dont know my dell inspiron e1505 admin password, how to unlock it ... in the system recovery options
The only way to reset the Admin password is through SAM database, first you need to create a USB bootable drive and download password reset program (it's DOS base) after you've created a USB bootable drive put the password reset program there and boot your PC to USB and type the password reset program name, and you are ready to reset the administrator password.
Oct 29, 2009 | Dell Inspiron E1505 Notebook
I have media direct on laptop inspirion 1505...it was not being used and now it comes on automatically and i can not get to opening page for password to internet. when I exit media direct express, the...
First hit ctrl-alt-del at the same task manager will open and you can shut it down there then go to control panel and click on add/remove programs, select media direct and click uninstall
Jul 27, 2009 | Computers & Internet
Inspiron e1505 forgot password
click start, then setting, then control panel then doulble click in the user accounts, select desired accounts then select "change my passwords" it is on the left side of the page.
Mar 21, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
136 people viewed this question
Alun Cox
