Question about Ariston Technologies Ariston XF905 Electric Single Oven
I have an ARISTTON gas range for eight years now,i never get to use the oven.. even once,now i want to use it but i cant find the manual anymore...i dont know how to bake,or use the oven...pls help me...my unit serial number is C 345 G(X) EX
I cleaned my oven 2 days ago and now nothing works what happen?
Cleaning can be fatal to an oven, even "self-cleaning" ones.
Nov 24, 2017 | Ovens
Hope you can help i have a frigidare 30 in stove 7 years old oven does not go on glow coil is working help thanks andrew
the "glow coil" /ignitor is weak and needs to be replaced , to get a bit techinal for a minute since the ignitor comes on at all that eliminates all other possibilities and the ignitor must draw between 3.2-3.6 amps to open the gas valve it indeed is coming on yet not drawing enough amps(getting hot enough) to open the gas valve.I base my oponion on 30 years plus as a appliance repair technician
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
Cant get oven to turn on. the only thing that works is the stove top n have to light it my self. My electical screen wont turn on which controls my oven
Check and see if the stove is plugged in. I suspect your DSI module has failed.
All these stoves ain't the same nor do they even work on the same principle. I am guessing from the picture you have a DSI system. For a more precise answer always post a mdle number. Most model numbers are posted on the oven frame of the lower drawer.
Here is your DSI service Manual
Dec 21, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not start correctly
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 09, 2010 | GE JGRP17 Gas Single Oven
My stove does not ignite even when glow light is on model 3127wtv
Turn off the gas supply to the range. Remove the oven racks,oven base pan,flame spreader.
Place a clamp on amp meter on one wire of the ignitor and turn the oven on to BAKE. When the ignitor glows it should read more than 3 amps. If it reads 3 amps or less replace the ignitor.
Jan 03, 2010 | Magic Chef Ovens
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
Control panel Roper gas range replace or buy new range?
4337979 Control-Clock/Oven
Retails for $206.90 easy to replace good luck..
Sep 28, 2008 | Ovens
Ariston Technologies Ariston XF905 Electric Single Oven Logo
48 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
