No installed display adapter - Computers & Internet
    Brigadier General:
  • 8,909 Answers
Depending on the make and model, specific software is required to access the firmware and adaptor.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
If you have a Toshiba laptop, go to Toshiba's web site for specific drivers.
I hope this helps.
Posted on Nov 09, 2010
Where can I find a driver/adapter for Advent X19W LCD Monitor?
Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
Dec 14, 2014 | Nvidia Computers & Internet
Display adapter
You can uninstall the display driver then install the latest driver from the dell website either on Intel website.
Oct 16, 2013 | Dell Computers & Internet
Solution for aspire 4745g when installing for ati driver it turn black?
An ATI adapter is a type of video adapter that is designed to be used on computers running Windows. If the adapter is disabled, you will not be able to connect any external monitors, video projectors or other similar devices to it, as your operating system won't be able to recognize it. Of the different ways you can enable this type of display adapter, one is through the "Display" manager in the Control Panel.
Click "Start." Click "Control Panel." Click "Display." Click "Change Display Settings." Click "Advanced Settings." Click the "Adapter" tab. Select the ATI adapter from the list on screen. Click "Properties." Click the "Driver" tab. Click "Enable" to enable the ATI adapter through the "Display" manager.
Or the driver you are installing is not compatible with your operating system or your computers hardware
Hope it helps
Jan 23, 2013 | Acer Aspire 5602WLMI Notebook
How do you disable the on board videocard on a hp p6130f?
Turn on the computer. Press the left "Ctrl" key. When the start-up menu appears, select "Safe Mode" and press "Enter." Once the computer enters safe mode, click the Windows "Start" button. Go to "Settings" and open "Control Panel."
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
Aug 26, 2012 | HP Computers & Internet
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
The movie is running slow on full screen
check if the display driver is installed or not in your computer, here is the step to check the display driver is installed or not,
step 1. go to start and select control panel.
step 2. double click on system.
step 3. after this a window pop up select hardware.
step 4. click the device manager and after this another window pop up.
step 5. in this window you can display adapter on 4th row.
if you cant see this display adapter row so you can see something with ? sign in other rows and you can see vga adapter or display adapter down there. if you see ? sign that mean this driver is not loaded you need to load the driver for your display driver. there is no problem in your LCD monitor.
Thank you for using Fixya
Regards
Manish
Jun 10, 2010 | ViewSonic VX2240W-2 LCD Monitor
How do you install the wirleless router?
1. Click Start, and then click Control Panel.
2. Click Network and Internet Connections.
3 Under or pick a Control Panel icon, click Network Connections.
4. Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
And Thanks.
Mar 18, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
Error in installing display adapter
Here's a link to the mainboard drivers:
http://www.mercury-pc.com/downloads_list.php?productid=563
Mar 13, 2009 | Enterasys Computers & Internet
I get a an error after installing my nivida graphics card to use dual monitors error: invalid display settings currently selected graphics display driver can not be used. It was written for a...
In that case, your pc might have a conflict.. it maybe the version of the display driver.. perform a clean install on the video card driver by doing this.. assuming that your PC's OS is WinXP..
1. On your desktop right click the icon My Computer and click properties..
2. On the System properties click Hardware then click Device Manager..
3. On the device manager window look for the display adapters then click the + sign on the left side..
then it will shows the display adapter you have on your pc..
4. Right click your display adapter then click uninstall.. from there your pc will remove the display adapter you select then it will ask you to reboot..
5. Now were assuming at this time that your pc has been rebooted.. Browse your Display driver and then install..
hope this will help..
Dec 05, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Alun Cox
k24674
