Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printed documents and pictures have dark red vertical lines
Everthing I print has dark red vertical lines through it approximately .25 inch spacing. What do I need to do to eliminate this problem?
  • Anonymous Mar 17, 2014
    Leaves dark lines on each side of the page about just inside the margin.
    Problem Solver:
  • 7 Answers
Does this happen when receiving faxes and photocopying?
Posted on Jun 16, 2008
Canon image runner c5800 printing vertical lines
have you ran a test page , the test will take about 30 sheets of paper it will test everything and will correct itself
good luck
Dec 04, 2013 | Office Equipment & Supplies
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
When scanning dots show up in a vertical pattern
Printer DPI and PPI Ratings, General Dots per inch stands for the maximum number of tiny spots of ink that the printer can place in a straight line where the spots are theoretically small enough (i.e. ignoring spreading or smearing effects of ink on paper) that if placed in every other such dot position leaving white space between them, the spots can be individually distinguished. Pixels per inch stands for the maximum number of unique positions in a straight line that the printer can place an ink spot under control from the outside world, namely from a computer connected to the printer. Lines per inch stands for how close thin parallel lines can be printed and still be distinguished in the finished printout. The spaces between the lines count as "lines". Pixels per inch and dots per inch originally referred to the same thing. The printer mechanism was under the direct control of the computer and was physically positioned and placed dots as directed by the computer. Back then, most printer mechanisms were limited to placing dots only in positions suggested by a grid of dots X per inch horizontally and Y per inch vertically, for example 100x100 dpi Nowadays, many printers put dots "wherever they want" as opposed to in positions suggestive of a horizontal/vertical grid. Still there is a minimum dot size and a minimum dot spacing. A picture file (image file) represents pixels in a uniform horizontal/vertical grid pattern. And the printer needs to make a finished picture of the size, say 5x7 inches, that the user chose regardless of the number of pixels in the picture file. To simplify the process of relating the pixel count in the picture file to the possibly non-uniformly spaced dots on the paper, the printer or its supporting software may generate a temporary intermediate picture file with a set number of pixels per inch. The printer may have, internally, several choices of ratio of pixels to dots and the published rating can be the largest ratio except that the published rating may not exceed the dpi rating. Therefore there might be three "per inch" values involved at a given time, the pixels of the original picture file, the pixels per inch that the printer works with, and the dots per inch of the printer mechanism. Pixels per inch is usually not mentioned with printers. All printers come with their own software (including parts called drivers) to install on your computer. Usually the software does not let you exercise control over individual dots using your picture file. Rather the printer takes your picture file or data file and uses its own built in logic to lay down the dots and create the printed output. We are led to believe that a printer's ppi is usually a fraction such as a half or a third of its dpi rating. When a temporary picture file is created, there are at least two levels of software in use. High level software (which may run in your computer) takes your picture file and creates the temporary file. Low level software runs in the printer, takes the temporary file and controls the dot size and dot placement on the paper. Sometimes a printer is advertised using a phrase such as "300 dpi 1200 dpi quality". This means that the printer has some way of making dark edges on a light background appear smoother than the first number would otherwise suggest. A printer with 300 dpi 1200 dpi quality definitely cannot resolve alternating dark and light pixels less than 1/300'th inch each. But curved and diagonal lines and color boundaries should not have jagged edges suggesting individual dots rigidly positioned on a grid with a 1/300'th inch pitch.
Oct 24, 2010 | HP LaserJet 3050 All-In-One Printer
KM7450 Vertical Lines in Magenta
I would replace the Magenta drum unit & developer unit
Jan 13, 2010 | Konica Minolta magicolor 7450 Magenta...
Vertical Thick Lines accross papaer on a HP Laserjet 3330
So the "White lines" went away when you replaced the cartridge, and now you have "dark Lines"?
It sounds to me like you have yet another bad cartridge. Is it remanufactured/ compatible?
Although, they can perform very well, they can also be awful depending on the source.
Return it and get another one, or different brand.
Jun 19, 2009 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
137 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
