Where are he bushes o aquarius 900 - Washing Machines
  • Washing Mach... Master
  • 3,463 Answers
The brushes are located inside the motor, depending on the production model, the motor could be in the top of the washer at the right hand side, or located at the bottom of the washer, best thing to do is to remove the top cover, and then you can see where the motor is located.
Posted on Nov 09, 2010
Hotpoint pump
Is the machine not spinning? May need new bushes. Sited underneath and wear down by making contact on drum.
Feb 05, 2012 | Hotpoint Aquarius WF210 Front Load Washer
Hoover Aquarius Washer Drier WD 440 Washing machine worked fine yesterday but today is tripping out and blowing everything in the house. Also washing inside the machine was very hot and water not drained...
sounds like the bushes have gone in the motor... about £20 from your local appliance retailer/parts department! or the filter may be blocked... clear the filter but it will get messy so have towels at the ready a hosepipe would come in handy or move it outside if you feeling strong!!
to check the bushes locate the motor not sure of position on these but near to the bottom you will see wires going to plastic parts each side normaly held in by a screew, take a wire off each plug in and see if it runs...
hope this helps
Aug 30, 2011 | Hotpoint Aquarius WD63 Front Load...
How do i change bushes on my wf440
hello go to this site www.espares.co.uk it will show you how to replace them or youtube hope it helps
regards
shaun
Apr 05, 2011 | Hotpoint Aquarius WF000 Front Load Washer
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I lost reverse on my '91 saab 900s 5 speed. sometimes lose 1st and 2nd gear. Thinking maybe gearbox nees lubricating ?
Had the same type of problems with my 95 Saab 900. A bushing in the shifter linkage kept popping out. Found out after lots of frustration there was a new shifter linkage mechanism out for 94 to 97 Saabs that fixed this problem. Not sure if it relates. I found the part here:
http://www.thesaabsite.com/900new/NG900manualtransmissionparts.htm
Nov 12, 2009 | 1991 Saab 900
Hotpoint Aquarius 900 WM61, washed but stopped spinning, about 6 wks ago, new brushes fitted old 1's had split everything worked fine, 6 wks down the line machine washes but doesn't spin again, bushes are...
hello carl check the module circuit board this controls the speed check the transistor on the boards for dry joints if discoloured change the board all the best
shaun
Aug 04, 2009 | Washing Machines
My 1991 Saab 900 is shifting perfectly except it will not go into
I've had a similar problem, and it was the rubber bushings in the shifter link; as some particular ones age they get sloppy and 5th gear seems to be the one that suffers. Others will age and disintegrate, then you won't be able to shift at all. If all the other gears are fine (no grinding, judder, popping out of gear or other untoward behaviour) I'd look to these rubber bushings, and replace them all while you're at it. They're replaceable at much less cost than a tranny rebuild, and are most likely that cause, i.e. after rebuilding tranny, you still won't get into 5th because the shifter won't have been rebuilt, just the contents of the gear box!
Check the "Bentley Bible" aka the Saab 900 Official Service Manual, costs about $40 from Amazon, for info, it's an invaluable resource!
16 valve manual: http://www.amazon.com/Saab-900-Valve-Service-Manual/dp/0837603137
8 valve manual: http://www.amazon.com/Eight-Official-Service-Manual-1981-1988/dp/0837603102
Get the appropriate manual for your car and enjoy the Saab!
Jul 27, 2009 | 1993 Saab 900
Windows will not stay up, they need reseting ?
Sounds like you may have broken so-called window glide rollers (aka window regulator bushings) which are the green plastic and metal clips that secure the window glass to the scissors lifts. Each window has two.
Window regulator bushings:
Part no. 4493433, $7.14 USD, at saabsite:
At eeuroparts.com
Part Code: 4493433
Part Name: Window Roller
Part Brand: Genuine Saab
Part Cost: $5.92 USD
Part Description: Window roller for any 94-98 900, 9-3 99-02 (and 03 convert), 9-5 all. 2 per window regulator.
Or aftermarket (Scantech)
Part Code: 4493433A
Part Brand: ScanTech
Part Cost: $2.99 USD
Remove the inside door panel to expose them and replace any that are broken.
Dec 06, 2008 | 1997 Saab 900
Vibration
my bike makes some vibration when the engine revs around 4500 RPM. It's atomado tre 900 le . Someone else had such bike or such problem ? I was thinking of putting some rubber under de clip on to help reduce it. Any more suggestions? are the engine mounts worn?? maybe you need to replace the boots/bushings on the mounts.,
Nov 10, 2008 | 2002 Benelli Tornado Tre 900 LE
Fitting "Bushes
you will have to remove the back then the motor then the motor brushes
Aug 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
