Question about Oceanic Delta 4 Dvt Regulator
I recently bought this from dive show but can you please tell me what the switch is on top of reg
  • 60 Answers
It changes the amount of resistance needed for the air to be released, ie if you are diving at depth you may feel that you are having to work hard to breath, if you adjust the lever it will become easier. In converse as you come to the surface if the reg starts to free flow you can adjust the lever to stop it. Happy bubble blowing :)
Posted on Nov 10, 2010
I have packed my computer in my backpack and after a few hours now i picked it up and found that it's in the dive mode: top line normally shows no-deco time = so now it's showing 9:59 (like in the...
All dive computers will automatically come off dive mode when they are out of water. sounds like you may have water in it. I strongly recommend that you do not dive with this unit but send/take back to the place where you got it. I would guess it is still under warranty. Hope that helps
Oct 19, 2010 | Tusa Zen Wrist Dive Computer (IQ900)...
Hey guys, im confused... i want to buy my new diving gear and i have come to a conclusion between two packages... these are : Scubapro : 1st stage din/int Mk17/395 reg + Oct R295 + seac sub BCD (First) +...
Denx7d could have not said it any better i have about 1300 dives on my gear and still in good shape and have annual service on my gear now i am a certified repair technician for scuba pro these regulators they sell are the best on the market hands down
Jan 21, 2010 | Scubapro MK11/R395 Regulator SCUBA...
I recently bought a 1978 Allegro motor home with 454 GM motor in it, the vehicle is missing all the belts, need help in showing me the routing of the belts, it does have P.S with two V grooves as well as...
Please make it easy on yourself.....
If you go to Autozone,NAPA etc. most have diagrams on their computers that they can show you or run off for you. You could/should take a photo of the top front and bottom front of the engine to show as much as possible. Your 454 is the same as that used on Chevy trucks... so it is not something special!!
Oct 10, 2009 | Chevrolet Classic Cars & Trucks
I have a SR1 that had the breathing resistance knob on the 2nd stage fall off during a dive. Any clue where I can get a new one without sending the reg in for service?
Not likely a dive store or the manufacturer will sell such a part due to liability concerns. That being said, the knob should NOT fall out.
You could contact the place you bought it seeking warranty repair.
Ditto with the manufacturer. If you call Sherwood and describe the problem there's a good chance they will replace the part (in house) at no charge other then postage. However, most manufacturers require annual inspection/overhaul of life support equipment to maintain warranty status.
Sep 23, 2009 | Sherwood SR1 Regulator
I Have a 2002 blazer that starts but motor dies, surges when accelerating
If this engine is a VORTEC then you may have a problem with the internal fuel system. Under the top plenum there is a fuel reg and poppet valves that inject fuel into the cylinders. Sometimes the tubes that run fuel from the reg to the valves can leak and cause your problem. This cannot be found with pressure check because this occurrs after the reg. PS fuel mileage will go down. Let me know if this helps.Moe
May 26, 2009 | 1999 Chevrolet Blazer
Mares Abyss Octo, brand new, not breathing well
It's possible that the perceived free flow problem is causing a more general lack of faith with the reg?
A correctly set up reg will never be too far away from free flowing in that transition from air to water - just as you dive in. This is not uncommon and shouldn't necessarily be determined to be a fault. Some manufacturers have gotten around this issue by allowing the user to switch the 2nd stage to a less sensitive setting (small knob on side 'pre-drive' & 'dive'). This means the reg can still be set up correctly but effectively put into an incorrect (for diving) mode while you are bobbing around on the surface getting ready to go down.
The fact that the abyss doesn't have this mode doesn't mean it isn't working right. If your shop adjust the sensitivity too far, they are going to make it harder to breath with. I have a couple of Abyss and sometimes experience small free flow. Nothing to worry about. You can look it up but the reg has been down to some record breaking depths without issue.
You haven't said which is your main reg - but the poseidon system runs a much higher pressure between 1st and second stage. You absolutely should not use this octo with poseidon, unless it has been ok'd by a authorized poseidon dealership.
In summary I can't see that your two problems are linked.
Feb 17, 2009 | mares Abyss Octopus SCUBA Equipment
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Reg Touchscreen
first of all calibrate ur touch
then if not works
please change ur touch pad
Sep 20, 2007 | Sony Ericsson Bluetooth handset pink...
Oceanic Delta 4  Dvt Regulator Logo
129 people viewed this question
Top Oceanic Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you an Oceanic Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
