Question about GE GTH18JBR Top Freezer Refrigerator
18 cu inch refrigerator ge hotpoint
Bought it new no sign of damage plug it in and fans run no cooling. turn control to highest setting still no cooling in freezer or fridge
My freezer is set higest and meats frozen ice cream soft the refrigator part is set on #9 but everything is not warm but just a little cool
Posted on Jul 04, 2008
Refrigerator not cooling, Freezer not freezing
no cooling at all on both sides? if thats the case do you have power to the unit ..lights on fans running then your compressor is not working check the starting components and hear if the compressor works also check the controls are they on or off? good luck..
Oct 05, 2013 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Wall between frig and freezer getting hot , fan not running ????
the fan is wired with a circuit board turn off and reserch parts on hotpoint ,
Mar 20, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
The fan is blowing and the freezer is cold, but the refrigerator in not cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 26, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Freezer not cold
Check Compressor. If its too hot to hold your hand on it then
you may need a new compressor. Check condensor fan, and check
evaporator fan
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Apr 18, 2010 | Refrigerators
Refridgator too cold and on highest setting
i'm guessing your fridge is over - packed with alot of food - i found if i made more space - temperature returned to normal cooling.
hope this helps
marneypants
Oct 02, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Compressor not comming on somtimes / freezer staying cool not cold / fridge cold
Turn the termostat to high, check the following morning. If unit is not cooling you need to replace the compressor. However, before replacing compressor make sure all the fans are working.
Sep 10, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Freezer will not get cold
Hi..
You need to check this following:
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
Good luck !!!
Regards
PCmania
Jul 10, 2009 | GE GSS25LGM Side by Side Refrigerator
Would not shut off
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 24, 2007 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
GE GTH18JBR Top Freezer Refrigerator Logo
146 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
