Question about Acer Aspire 9300 Notebook
How can I replace the keyboard on my laptop the keys stick I wasted water on it
    Brigadier General:
  • 8,909 Answers
It is probably better to show you a drawing of the Acer and where the screws are. From that it is easy to work ot where the bits all fit together. It apears there is a problem with Fixya, I cannot upload a drawing.
Try this:
Disconnect the power source and remove the battery.
Remove the hinge cover, it flexes fairly easilly but don't force it!
There will be a couple of screws fixing the keyboard down. Remove them and the keyboard becomes loose. Be careful with the flat cable and un plug it. (The socket has a clip that holds the cable in place, Use Care!).
Fit your new keyboards.
Hope this helps.
Posted on Nov 09, 2010
Keybd keys are sticking
Be prepared to buy a new keyboard... Remove AC and DC power before working on laptop. Many laptop keyboards come off with the removal of 1 to 5 screws from the bottom. Some, however, require the palm rest to be removed, then a couple of screws that hold in the keyboard. Be careful when removing and replacing cables.After removing keyboard, rinse with water and let dry thoroughly before re-attaching and powering up. You cannot remove individual keys, so don't try.
Apr 12, 2010 | Fujitsu LifeBook S6510 Notebook
I use my computer for gaming and when i move around with the arrows they stick sometimes in one of the directions un til i tap that key again, is this common for the classic keyboard 200?
Logitech keyboards are excellent both in quality and longevity.
Make sure some sugary drink has not been spilled on the keyboard.
This will make the keys stick and repeat. I have had good luck with Dawn and warm soapy water. Just make sure the keyboard is completely dry before putting back into service. 1-2 weeks drying time. (IF you dunk and submerge. Only the most severe)
Never EVER dunk a laptop in water to clean the keyboard.
I know I know... but someone will try it. :)
Check to make sure the windows sticky keys are turned off.
Sounds like dirt or a soft drink is causing this repeating pattern you described.
Oct 10, 2009 | Logitech Classic 200 DH968019 Keyboard
Keyboard malfunction
You can try reseating the keyboard but then if the same keys aren't working then that means that the keyboard is bad and would need to be replaced. Could be either keys sticking or water got spilled on the keyboard.
Aug 16, 2009 | Toshiba Satellite L305D-S5881 Notebook
My keyboard on my laptop has a broken key, there are 2 clip underneath it and one of them is broken where can i buy a new one?? The key that is broken is the ALT key(bottom left hand corner)
Sure, they can be purchased for a cheap price from ebay. tell them what key for what model and they wil send you ithe key, and the two clips and anything else you will need. Type the model of your laptop, and add "keyboard replacement key". good luck
Jun 18, 2009 | Computers & Internet
Sounds like some water or other liquid got into the keyboard or could be that some keys are sticking. With the laptop turned off. Run your fingers thru all the keys going from left to right, up to down. This will ensure that if any keys are sticking that they will become unstuck.
Turn on the laptop and if you still have the problem then the keyboard is bad and would need to be replaced.
Ben
May 24, 2009 | Toshiba Satellite A135 Notebook
My acer laptop keys are sticking and to hard to push down. I need to replace them how do I do that?
no they don't need replacing they just need cleaning, you can remove the panel that goes accross the top of the keyboard (above the F keys) if you remove this panel you can remove the keyboard too, it is connect to the laptop with a ribbon cable that you can remove. when the keyboard is free all you have to do is run it under warm water (not hot) and clean the keys gently with washing up liqiud that you use for the dishes, keep on running warm water on it until the keys are free (you may have to repeat this process if the sticking persists) Now for the important part, you have to leave the keyboard to dry for at least 24-48 hours in a warm dry room before you can put it back in, press on the keys periodically to make sure they are free
regards
Nov 23, 2008 | Acer Computers & Internet
Wireless keyboard keys sticking
on most keyboad you can take of each key. Try to get a flat head screw driver and pop it of with some force. You then can clean the keys. If this does not work you might need a new keyboard. Do not use water (or very little)
Sep 20, 2008 | Dell Latitude C640 Notebook
Acer Aspire 9300 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
