Question about HP Pavilion dv9000z Notebook
My laptop fails to open.its lights turned on when open but after a while it will be gone then light again.
  • 170 Answers
Most likely it is overheating.
check to see if you hear the fan working.
also- check the System event log to see if it is reporting on any malfunction:
right click on My Computer and select Manage --> click on Event Viewer --> System log
Posted on Nov 09, 2010
Connection screen seems to be broken ASUS X52JR
Try shining a bright light at the screen. See if there is movement. If there is either the back light has failed or the screen has been deselected, in which case go to the battery icon,right click and choose mobility. You can turn it back on from there. If not, order a screen through flea bay or wherever you want. When it arrives, pose the question again.
Jan 12, 2014 | Computers & Internet
My toshiba computer has turned off and a red light flashes when I try and turn it on again
Sounds like there is no power to the laptop so teh laptop has gone into hibernation. Make sure that the laptop has working mains power.
Dec 10, 2013 | Toshiba Satellite Computers & Internet
I have a compaq presario cq56 one day the light beside the charger port turned red and now the laptop wont turn on when the battery is out the light turns blue again but still nower power to the laptop
either the power supply has gone bad or the motherboard is fried, that's usually all that those light codes mean well blue is the normal color but it will won't power on because the damage is done. might call compaq support and see if they can walk you through a few things though
Feb 22, 2013 | Computers & Internet
My led lights in my laptop emachine dont want to turn on anymore how i can turn it on again....its usually opens when i open the camera but now when i tried opening my video camera there are no lights...
Is the laptop working as normal? If so then it would seem only the leds are gone , most probably a power issue, I suggest you just call your laptop make , give them your serial and see if they can replace it
Feb 15, 2013 | Computers & Internet
I have a Toshiba Tecra-M2-S410 machine, and it does not turn on anymore. When I remove the battery and plug it in, the power light turns green as expected. When I press the power button, two other lights...
Hi mohammad - seems the LCD of the laptop is gone bad . as u said u gets the light on the laptop and also sound and then it goes dark - shows possibly the LCD gone bad .
Give a try with this if you have a computer in your home - on the back of the monitor you will find a VGA cable (probably with a blue color end which goes to cpu ) unplug it from cpu and plug it in the laptop (side of laptop you will find a same input VGA slot blue color ) and boot your laptop after turning on both (monitor and laptop) if you find the screen on the monitor then it will be sure that your laptop LCD has gone bad .
On your laptop if you are not able to find the boot screen also that refers to LCD brokerage -anyway try the above you will be sure ..
Oct 01, 2010 | Toshiba Tecra M2-S410 (032017233812) PC...
The screen suddenly became blank....and it turned off...its not starting again
Major hardware fault. the laptop must be opened and tested - if you're lucky it's only a failed memory module. If it's , as usual on this models, the mainboard then it will be very expensive to replace.
Aug 05, 2010 | Dell 9-Cell Battery XPS m1530 laptop....
HP Pavalian laptop screen gone black and blank.
It seems like the lcd back light may have failed can you see a faint image on the screen when you look really close, try it with a torch. If you dont see even the faintest image the inverter has failed and needs to be replaced. If you look on youtube again and search for videos of replacing both the back light and the inverter it will give you some info on how to change them. Do a google search for hp spares and you will probably find what you are looking, i think the inverter is about £30 and the back light is bit cheaper. hope this helps.
Feb 11, 2010 | Computers & Internet
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
Laptop does not power on !
first of all change ac cord and batter then try with the fan
May 16, 2008 | Acer Aspire 3004WLCi Notebook
HP Pavilion dv9000z Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
