Question about Dell AS500 Sound Bar Computer Speakers
How do I take apart the speakers to fix a broken wire? The wire that connects the speakers to the computer is broken very close to the speakers themselves. I need to get the speaker bar apart to solder the wire back together. Is there a specific trick to doing this or is it just screwed and glued together?
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
A unit like this is probably not designed for disassembly or repair. Possibly the grill can be pried off and then access gained from the front by removing a speaker. Or possibly not. If you want to save this unit you may have to get surgical as far as cutting or drilling your way in. Keep in mind that you'll need to mend any openings you make in the case when you are done, to preserve the unit's acoustic properties. Epoxy may be your friend there.
Posted on Dec 18, 2017
SOURCE:
rachelgeek23
  • 155 Answers
SOURCE: can i add any speakers to my dell vostro 200?
No you don't. As long as you can plug the speakers to the green port on the back of the computer, the speakers are powered and the volume knob on the speakers is turned all the way up. You should hear sound.
Also make sure the sound is not muted in windows.
Posted on Oct 04, 2008
SOURCE: realtec hd speakers no sound
Hi i have speackers.... but i have no realtec and i have no sound at all i tryed to look for the
volume bar buti can not find thatas well, and i do not have ac97 audio configuration as well
to ut it all together i got nothing to hear music, i hope you can help me out on this problem
please thank you.
from Debbie
Posted on Mar 09, 2009
  • 63 Answers
SOURCE: Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Posted on Aug 19, 2009
Testimonial: "This fixed my problem 100%"
dlundmark
  • 797 Answers
SOURCE: want to replace computer speakers jack
You may be able to cut open the old plug and see what connections go where.
Posted on Aug 24, 2009
Testimonial: "I'll give it a try thanks"
  • 979 Answers
SOURCE: my speakers have 2 wire connection and i need to
Good day sir/maam, if you want to install your loud speakers to your Laptop, you may need a power amp. as shown below. fa67f35.gif
Posted on Oct 08, 2009
Memorex speaker keeps cutting out. I believe the little black wire hookup is cracked where it is connected to the unit inside housing of speaker. The pic of type of speaker is at the top of the page where...
These housings are often glued together at the factory and are not meant to be opened. You may have to break it to get inside. If the wire to the voice coil is broken...really no fix, if the wire is bad between the case and the speaker you can probably fix it.
Nov 21, 2014 | Cars & Trucks
THE WIRE THAT GOES FROM THE SPEAKER INTO THE PC IS BROKEN CAN IT B FIXED
Go to RadioShack. Take the speaker with you for the exact replacement.
Jan 17, 2014 | Logitech Z323 2 Speakers
JBL Creature Speakers
I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
I hope this works for you.
Dec 09, 2009 | JBL CREATURE II Computer Speakers
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
Here's my problem: I have 5.1 logitech speakers. The plug where the yellow jack goes into the subwoofer seems to be broken. No sound coming from this speaker (rear left). The problem isn't in the cable...
2 possibilities, either the connection coming out of the sub has gotten disconnected on the inside of sub or that channel is bad on your amplifier in the sub. The only way to know for sure is to open the sub up and ck.
Aug 02, 2009 | Logitech X-530 Computer Speakers
Yellow plug problem
Yes, this is easily fixed. Take the cabinet apart, it'll probably be obvious what needs to be done. Need help, let me know.
May 02, 2009 | Logitech X-530 Computer Speakers
Dont know where an item should go
This is an internal speaker. Find the speaker pins on the mother board. Should be somewhat close to the front panel connections.
Mar 23, 2009 | Abit NF7-S V2 Motherboard
Nintendo ds
Have you tried headphones to see if there was not sound all
together
Jun 13, 2008 | Nintendo DS Console
Phono lead connection.
Take it apart ind see if a wire is broken. You can use a meter for this. You could test the wires on another speaker also.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 03, 2008 | Harman Kardon SoundSticks II Computer...
Dell AS500 Sound Bar Computer Speakers Logo
421 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
