Question about Samsung Digimax L730 Digital Camera
Power on problem
Trying to press the power button on camera but doesnt turn on
  • 1 more comment
  • stanford2491 Aug 23, 2008
    Samsung L730 still digital camera
    camera will not turn on..not even plugged into wall outlet. we are using rechargable batteries and are probably not charged....does this camera require the battery to be charged or will it turn on if plugged into an outlet?
  • celias1 Aug 24, 2008
    I turned my samsung L730 off, the lens didnt go in, and now it wont turn on, ive tried pluggin it into the power and the computer
  • Tim Babcock
    Tim Babcock May 11, 2010
    Have you replaced the batteries?
I had the same problem. I connected it to the pc.
Then I took the battery + memory card out, and left it for quarter of an hour.
Put them both back in and it worked :D
It's worth a try anyway.
Posted on Aug 28, 2008
  • 797 Answers
Always explain if you are using new batteries or recharged and if they are charged.
If that does not start the is internal, and could be the start button or some other problem....and that can lead to a lot of things internally.
Posted on Aug 01, 2008
I have the word Access come up on the screen and i can't take photo's i can access all other funtions on the camera. Is there a trick? OR A BUTTON TO PRESS HELP!
hi johnjones931,
the problem that you have is a common issue with SONY digital camera which has a retractable lens. The error is brought about by the inability of the lens to retract or protrude fully. You may try these steps ...
1. turn off the camera then remove the battery. Once battery is out you may press on the power button for 1 minute. This process is called power cycle, this way we are eliminating static electricity that may be causing the issue. After doing the steps mentioned put the battery back and then try to operate the camera. if it doesnt work try next step.
2. Have the camera on viewing mode (since you will only be getting the word ACCESS on the shooting mode). them press Menu button and look for the (SETUP) icon the looks like a toolbox . once the toolbox icon (SETUP) is highlighted press the middle control button to select it. Then go to SETUP1 (icon: toolbox with number 1) then select Initialize. This will reset all the stored settings on your camera.
Jun 15, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
When i turn on the camara it says to turn off and turn on
initialize the settings of the system.
press the menu button then look for the toolbox icon with a number one at the bottom then select initialize. click ok and confirm selection.this process doesnt delete your pictures.
if menu is not accessible you can also try to remove battery then press and hold power button for a min then reinsert battery and try to turn it on again.
Sep 11, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
My camera wont turn on. i press the power button, but it only blinks and doesnt turn on. why?
Having received no response in over a month, I assume this is no longer a problem.
May 27, 2010 | Sanyo Cameras
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
My cannon power shot sd600 viewer doesnt turn on
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. Try pressing this button one more time to see if it turns back on.
Oct 13, 2009 | Canon PowerShot SD600 Digital Camera
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
It says turn the Power off And on Again
try to reset camera first. there is a reset button right bellow zoom buttons. press that reset button while camera is turned on. if it does not work, remove the battery from camera for 30 seconds. then reinsert and try. if these steps would not resolve issue then your camera needs service. check this link,
Mar 19, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Not powering on
The manual indicates that the green light flashing once indicates that the camera is powering down. (see page 218 lamp indications)
The first thing you can try is to turn off the camera, remove the battery, remove the memory card. Hold for one minute , pop the battery in(but not the memory card) turn on the camera by pressing the power on buttn and holding it for 15 seconds. This will not only reset the camera but also force the motor to retrace/extend the lens if it is a lens related issue that is causing the camera to shut down.
Let me know if you need more help
Jun 04, 2017 | Casio Exilim EXZ75 Digital Camera
My problem is with the vivicam 3188 camera. I cant get the flash to come on. The manual only says it will noy come on if the batteries are needing to be replaced. Well my problem is I bought this camera on...
remove the batteries from your camera and the press the power button for few seconds say 20 sec , then release it.. put the batteries back to ur cam n try... tis is how u reset ur camera.... try tis
Jun 24, 2008 | Vivitar Cameras
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Samsung Digimax L730 Digital Camera Logo
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
