Batteries failing in my logitech mouse, how do I change them?(MX revolution), where do I get them? please help, fading fast!
  • Tommy Su May 11, 2010
    oops..accidently click post it....
    A good practice when using rechargeable batteries...is to fully charge your device out of the box. Do not keep charging your device if there's still a battery charge on it...Once your device is about to run out of battery...then full charge it again.
    hope this helps!
    is your charging station not working? Your MX Revolution mouse uses an integrated Li-Ion battery that is recharged on an AC powered base station you plug into the wall. Let me know if your charging station isn't charging or if its your Li-lon battery.
    A good
    Guru:
  • 859 Answers
Your batteries are currently dead and you need to know how to replace them. Do I understand this correctly? Thanks.
There is an access panel on the bottom of your mouse. You will see a little depression for a thumbnail for a dime to lift it off.
Despite their reputation, Li-Ion batteries do need to be replaced from time to time, about a year or so. Two batteries may run you around $20 and don't skimp on brand.
Once you have the new batteries let them drain down to empty and only then charge them on your charging station.
Does this answer your question?
Regards,
Worldvet
Posted on Jun 16, 2008
Logitech mx revolution
Hi
Maybe your registry is not clean. You can use registry fixing software and then run registry analyze. and restart your computer.
Jan 19, 2014 | Logitech MX Revolution 931689 Mouse
MY LOGITECH MX REVOLUTION MOUSE NOT RESPOND
There are a number of reasons why your mouse isn't reponding:
  1. Check that the batteries are full
  2. Check that the mouse is synchronised with the adapter
  3. Check you have the correct drivers installed.
If none of these things help you, then if your mouse is still under warranty, I'd ask for another one.
Good luck! John
Mar 13, 2011 | Logitech VX Revolution 931690-0403 Mouse
Mouse will not charge when put in the base
I have a very bad solution about this, but it works on my mouse that also doesn't work. Try to put a tiny bit of water ( or spit Oo ) on the little, usually copper, receivers on the mouse. That makes for a better contact. Just get your finger wet and touch those receivers.
May 15, 2010 | Computers & Internet
Drivers
Because you don't list what model Logitech cordless mouse you have, look in this list to see if yours is on it. If it is, click on the link and download and install the driver. This download has the latest drivers and SetPoint software for Logitech cordless, wireless and Bluetooth pointing devices (mouse).
http://www.softwarepatch.com/utilities/logisetpoint-dl.html
Specifically the mouse driver is for the following models:
  • Anywhere Mouse MX
  • Cordless Mini Optical Mouse
  • Cordless Optical Mouse
  • Cordless Optical TrackMan
  • Cordless TrackMan Optical
  • Cordless TrackMan Wheel
  • G1 Optical Mouse
  • G3 Laser Mouse
  • G5 Laser Mouse
  • G500 Gaming Mouse
  • G7 Laser Cordless Mouse
  • G9 Laser Mouse
  • G9x Laser Mouse
  • LS1
  • LX3
  • LX3 Plus Laser
  • LX5
  • LX6
  • LX7
  • LX8
  • M110
  • M205
  • M305
  • M500
  • M505
  • M555b
  • M705
  • MX 610
  • MX 610 Left-Hand
  • MX 620
  • MX Revolution
  • MX1100
  • Optical Mouse
  • Performance Mouse MX
  • Racer Mouse
  • Spot Mouse
  • Tiger Mouse
  • Trackman Marble
  • TrackMan Wheel
  • Trackman Wheel
  • V100
  • V150
  • V200
  • V220
  • V320
  • V400
  • V450
  • V470
  • V500
  • V550
  • VX Nano
  • VX Revolution
  • Zebra Mouse
I hope this helps and good luck!
Please remember to vote 073d6e6.jpg and leave a testimonial.
Nov 03, 2009 | Logitech Cordless Mouse
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Laser Mouse MX 1000 By logitech
try replacing with new rechargable batterys
Nov 03, 2007 | Logitech Cordless Mouse
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
