Question about Radio Shack Pro-94 Scanner
Radio Shack 17-6020 Paging system
I have no user manual. I need to know how to program the pagers to the base station for a Radio Shack 17-6020 Paging system. Your menu would not recognize this product so I just entered something that started with Radio Shack.
  • 405 Answers
Good Day,
See this link for all available documentation:
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=17-6020&Name=Pagers&Reuse=N
Hope this helps
Posted on Jul 09, 2008
Http://support.radioshack.com/support_phones/doc64/64737.pdf
try this
Posted on Sep 10, 2009
Vertex 231 set to receive an alert tone will not trip while pagers set the same way do. They used to, 8 radios stopped performing properly within 1 1/2 months of each other
It is most likely the encoder. It sends the signal to make the radios act like pagers. Two tone radios and pagers use almost the same exact format for programming. Has anyone worked on the base station or encoder? That is where I would start. Do you have the Vertex software and cables? It could be called a timing setting. This may not be a simple fix. Is there a service shop nearby? We've worked on pagers over 30 years and VX 231's for 12 years. They simply do not stop working unless someone adjusted something.
Feb 10, 2017 | Vertex Radio Communications
What if the Frequency of Motorola PG302cb
The PG302cb pager is dependent upon a paging system. Radio Shack has posted some details about this model at http://support.radioshack.com/support_phones/18664.htm There is a link for the user manual, along with other specifics. Upon a glance, we did not see the frequency bandsplit for this model.
Best regards.
Oct 13, 2014 | Motorola Radio Communications
How do pagers work?
Pagers, also known as beepers are small telecommunication devices that carry short messages. There are one-way pagers that can receive short messages or phone numbers or two-way pagers, that allow the user to send and receive e-mail, sms messages etc.
Paging works through a subscription service who pass on the messages to other pager subscribers.
Jan 23, 2013 | Radio Communications
Need user manual for JVC PC-X202 or instruction on programming
I should try the JVC website, many makers have free PDF of user manuals.
Jun 04, 2010 | JVC PC-X202 Shelf System
I need to know how to program this scanner. Radio shack pro-2055
The programming instructions are too detailed and lengthy to post here, so here's a link to the manual for your scanner. It will walk you through the programming process.
For an extensive database of active frequencies and systems in your area visit
www.RadioReference.com
or
www.CityFreq.com
If this response helps, please take a moment to post a rating. "Very Helpful" would be appreciated.
Dec 04, 2009 | Radio Shack Pro-2055 Base Scanner
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
HOW DO I SEND A FAX ON THE BROTHER MFC-5440CN? LOST MY MANUAL
Remote Fax Options;
5. Press Stop/Exit.
Setting Fax Storage
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
these faxes.
PC Fax Receive.
Press Menu/Set.
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
the CD-ROM.)
Apr 22, 2009 | Office Equipment & Supplies
Programming Page Button
You could look in the station user's guide and program paging. This may work, or not, if you're paging internal and outside do this:
From your phone press Feature 00 the button and then Intercom *70.
If you don't want all the idle phones in group 1, but just the outside speaker, press 70 alone.
I'm not positive, but you may have to delete the button in centralized programming if it is already assigned a "CO" line.
Centralized programming is done from extension 10 or 11 and involves the system manual and knowing where the overlay buttons are.
Post back if you need a basic Partner ACS manual or try www.avaya.com for system manuals.
Carl
Feb 20, 2009 | Avaya Corded Phone avaparp18d
How to program
I uploaded the manual for you to my server please save a copy of it onto your computer for future referance.
http://www.files.hpifdesigns.com/pdf/2051rspro.pdf
Aug 02, 2008 | Radio Shack Pro-2051 Base Scanner
Programing pager tone alerts
The scanner itself does not directly support decoding of pager tones, but if you know someone who can manage their way around a bit of soldering and hacking, they might be able to rig something up with an old pager which could be triggered from the audio output jack from the scanner.
May 15, 2008 | Radio Shack Pro-2055 Base Scanner
Radio Shack Pro-94 Scanner Logo
659 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
