Question about Linksys Wireless-G WRT54G Router
I can't open the link http://192.168.1.1...please give the fast setup for my WRT54G router broadband so that ican use my router....thanks
AvioriX
  • 689 Answers
SOURCE: WRT54GX4 Wireless Router Setup Problems
Hi Randy
Reset the router
Use regular way to configure the Router.
In computer side
Go to Start>Connect To>Show all connections
a new window (Network Connections) will open,
Right click on the "Wireless Network Connection"
Click on "View Available Wireless Networks" You will see "linksys" with the highest signal level. Connect it
after connection go to web browser; type 192.168.1.1 and hit enter. It will take you to Linksys setup page which is integrated in the router. after that you can do any settings you want.
Please post here if you need further assistance
Good Luck
Posted on Jan 12, 2008
  • 19 Answers
SOURCE: Useing WRT54G WITH STARBAND
your starband is if im right the cable modem ? connect the modem to the router and then the router to the computer ? then run the linksys easy connect @ www.linksys.com/support
Posted on Jul 19, 2008
Geekman
  • 32281 Answers
SOURCE: how to setup Linksys Wireless-G Broadband Router
Have you already setup one of your computers to connect to the Internet using the wireless router?
If so you can setup the second computer the same way and it also will connect to the internet. There is no need to access the Internet through the other computer.
Posted on Sep 21, 2009
  • 107 Answers
SOURCE: WRT54G keeps disconnecting itself, requires
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Posted on Mar 05, 2010
BugsMaster
  • 22 Answers
SOURCE: hi please help me my linksys wrt54g router is only
The information provided is defnitely not sufficent to help - however considering that you already have aanother computer which is wireless, mentioned below are the steps -
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
> close all the windows opened till now
Step 2 :
> click on start
> Select Run - new window will pop-up
> type "Services.msc" - new window pops up
> scroll down to the bottom of the list
> right click on "Wireless Zero Configuration" and Start (if not already started)/Restart the service.
> now close all the windows and search for wireless networks again
you should be able to find it
Posted on May 10, 2010
How to log into mybrouter
Linksys WRT54G Wireless-G Broadband Router
  1. Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
  2. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
  3. You should see the Setup page shown below
Mar 25, 2013 | Linksys Wireless-G WRT54G Router
Password protect
run link sys advisor and it will walk you through the password setup
Jan 12, 2011 | Cisco Linksys WirelessG Broadband Router...
I"m tryingo to connect my
I suspect that you have setup your router to expect a password of sorts and your lap top is not sensing the auto find feature. Check:  http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/  for a primer on how to setup the WRT54G router.
Nov 27, 2010 | Linksys Wireless-G Broadband Router
I lost my driver CD for linksys WRT54G broadband wireless router, what should i do? thank you
you can download the driver from the following link:
http://www.nodevice.com/driver/WRT54G/get43729.html
Nov 17, 2010 | Linksys Wireless-G WRT54G Router
I had secured my linksys wrt54gs it stayed secure for a while but i cannaot get it back into a secure mode how do i put it back in a secure mode
reset the router in admin mode and reload the settings again,
also make a new user account and save the password info so you can access it again later
I have an example of a router setup,
the basic steps are similar and easy to understand too,
check my tpis and tricks on this link below.....
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
Please rate me thanks MISTERDJ
May 07, 2010 | Linksys WRT54G Wireless-G Broadband Router...
I want to security enable my wireless internet
What you are asking about is called Wep security and is available in your router control panel ("http://" whatever your router is set to) then go to wireless>security and setup a Wep key. You can also go to this web page for more info:
http://www.linksysbycisco.com/US/en/support/WRT54G
Good Luck...
Tim
Mar 26, 2009 | Linksys WRT54G Wireless-G Broadband Router...
Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
Oct 10, 2008 | Linksys Wireless-G Broadband Router
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
