Question about LG LS-L1210CL Mini Split Air Conditioner
Do these a/c units come with cables to plug in the inside unit into a receptacle
  • 81 Answers
They are usually powerd from the mains power board in your house on a single separated circuit braker. they rarely are plugged in from the indoor unit into a power outlet
Posted on Nov 09, 2010
Testimonial: "thanks big help cus i am in afghan and i couldnt get a straight answer from anyone. But thanks for your help. Sgt Lambaria, Marcos J. USMC"
  • Simeon Hill
    Simeon Hill Nov 09, 2010
    Are you looking to buy an air con or install it your self or just asking?
  • marcos_lamba Nov 09, 2010
    Well i am an electrician. And i take orders from other people who are civilians and they are requiring us to install the inside unit and provide the ac with a cable that has a hospital plug on them so they are able to be plugged into a receptacle.
My dogs chewed and ripped out the electrical cord to my haier 10000btu a/c unit, model# hwr10x1c. I know where the the green ground goes, but where do the Other 2 go?
A 10,000 BTU A/C is probably a 110 volt unit. You are correct that the green wire goes to the ground terminal of the plug. The red or black wire is the "Hot" wire and would go to the "narrow" prong or "right" side of the receptacle - when the ground is on the bottom (if it is installed correctly) as you look at it. The white wire goes to the wide prong or left side of the receptacle. If the plug is fine and you have to connect the wires to the unit, there should be a wiring diagram to follow inside or on an electrical cover plate. Polarity is critical, so be sure what you do or let an electrician do it for you. Good Luck!
Mar 30, 2017 | Heating & Cooling
Why there no power to unit
Check the outlet to make sure there is 110 volts to receptacle. If there is power there than you will have to check inside the unit to make sure the cord is delivering power to the unit. It probably does have power to the unit if the receptacle. In this case the electronic circuit panel is bad, which means replace with a new circuit controller.
Jun 10, 2014 | LG LP0711WNR Portable Air Conditioner
We have a 96 rexhall rv. we have had the unit plugged into shore power from the house and had been running the air conditioner. it ran great about 4 times and now we can not get it to kick on with just the...
If your plugged in to a 15 amp household receptacle, then an extension cable of any kind or length, then that is likely your problem. An AC unit should have 20 amps of good power available to it. If your using an extension cord of any kind, and it is any less than 12 gauge wire, then that will cause a drop in voltage as well. Obviously the best scenario would be to install and wire a 30 amp receptacle outside your house just for that use, if done often. Take a voltage reading at receptacle, then inside RV, and see how it is probably a little less without even the AC on, then when AC kicks in, or tries to.
It may work once in a while, but it's not good for the AC to try and operate on low voltage, which causes a higher amperage draw.
Aug 27, 2011 | Dometic Rooftop RV Air Conditioner
What type of wall plug can I use for this air conditioner! My whole house is 110 or 220
If it is a 110 unit,use a regular wall receptacle ,if it is a 220 unit,use a 220 receptacle for 220 it will be made larger and different.Draw a picture of the plug on the end of the cord and go to the hardware store and get them to help you i d the plug.some 110 units are 40 amp,and are a little different than the regular 110 house hold 20 amp receptacle.
Sep 15, 2010 | Airtemp B3Q06F2A Air Conditioner
C330 will not power up when plugged into power receptacle in car
First, check the car's power receptacle by plugging in another device that definitely works (or take your gps to another car). Cars generally have a fuse associated with the receptacle that can blow. The second most likely problem is that the internal battery inside the c330 has died. This is especially likely if the unit is old (more than 1 year) and if you live in a climate with extreme heat or cold (which reduces battery life). This video shows how to replace the battery:
The company that produced the video sells a kit which includes the battery and tools necessary to replace the battery yourself. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+STREETPILOT+C330&Show=ExtInfo I swapped the battery of my brother's dying GPS using the aforementioned kit and all went well. His Garmin is back up and running smoothly.
Hope this helps.
Jul 11, 2010 | Garmin StreetPilot C330 GPS Receiver
GFP outlet unit is plugged into in crawlspace
They have been known to get weak/faulty, at times & need replacing. Be sure you have proper voltage at receptacle, & good, heavy cable to it. Is there another receptacle you can try to see if it trips breaker?
Aug 03, 2009 | Honeywell Heating & Cooling
Symphonic 13 inch tv vcr combo
Solution steps:
1. Make sure that the cable is not plugged into the mains receptacle.
2. Open up the unit
3. Inspect the board. Look out for a glass fuse rated about 3A/220V near one corner of the board. It is close to the mechanical ON/OFF switch on the TV. The cable normally plugs into a socket made up of two vertical pins an inch or less from the fuse. Sometimes these are marked with a squiggle (~) or two (~~) to signify that the mains power goes there.
4. If the cable terminator (end of the cable opposite the mains plug) was cleanly pulled out, then well and good. In that case simply plug it back in. If not (i.e. the cable is damaged, then you may have to remove the terminator and solder the cable directly to the board.
5. To pre-empt any further "pullings", make a knot on the cable inside the TV where the cable comes out so that there is some resistance to the pull.
6. Close the unit and enjoy.
Jan 21, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Lost power- will not come back on
If you have a multimeter you should be able to check the out voltage on the powersupply to make sure the power cable isn't at fault. You may also try wigling the power cord a little bit to see if the unit will then get power. If so you have a faulty powercord. If there are any fuses they should usually be accessible from the outside; that's the point with them - they should be easy to change. I would put my money on the power cable. If you have access to a diferent power source try that out. If the unit works with a different power source your power source is at fault. If it still doesn't work the problem is within your unit. Check to see if any pins on the power source and/or the units power plug might be bent or dirty.
Mar 07, 2007 | Magellan RoadMate 700 GPS Receiver
LG LS-L1210CL Mini Split Air Conditioner Logo
65 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
