Question about Toshiba Televison & Video
Line from top to bottom - Toshiba Televison & Video
    Problem Solver:
  • 11 Answers
A single black line means bad panel while colored line means controller bd. or ribbon cable needs to be cleaned and reseated.
Posted on Nov 09, 2010
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Hot water bypass
On the back side of the water heater you should see a water line connection at the bottom and one at the top. There should also be a water line connecting between the top and bottom lines. The bottom is cold water input and should have a valve. The top is hot water out put and may or may not have a valve, depends if there is a check valve installed. and the connection line between the two will have a valve. If you are wanting to bypass close the top and bottom valve and open the middle valve. If you are wanting to use the water heater, open the top and bottom and close the middle valve. Open the Hot Water on your kitchen sink and wait until you have a steady flow of water before you turn on the water heater.
Jul 11, 2014 | Keystone RVs
BUSH AE56SW. Need to know what picture to turn the dial to to use the oven ?
The icon with the 2 lines (top and bottom) turns on both the top and bottom elements. The icon with 1 line at the bottom turns on just the bottom element; this is the bake element. The icon with the single line at the top is for broiling.
The manual for the Bush AE56SW is available from Argos here: http://argos.scene7.com/is/content/Argos/4893945_R_D001pdf . The oven knob control diagram is on page 8.
I hope this helps.
Jun 04, 2014 | Ovens
There a multi colored lines across the entire screen how can i fix this? you can see the TV on.. behind these multi colored lines... very faintly.. please advise how this can be fixed.. chris trizano-...
Hello; Not much info given. Are the lines from top to bottom? , and does EVERY line go fully from top and bottom. If the lines don't go FULLY from top to bottom, you have a cracked LCD panel ( cost more than TV sold for ). If they all go fully from top to bottom, It can still be the LCD panel OR the LCD controller board ( much less expensive ) John
Dec 19, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
Press the show key (top right arrow)
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
Press the next key (bottom right arrow) .
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
Dec 23, 2009 | NorStar M7310 Phone
Meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Lines on top and bottom on projection TV
What sort of lines? - do you mean like it is in widescreen mode with a black band top and bottom? Do you mean you have clear straight lines, or streaks or scratch-like marks? Is it the same for all input sources (cable, DVD/VCR, satellite, PC, camcorder etc.? Could you post back a photo of the lines? Waiting your info:)
Jul 16, 2007 | Sony KP-43HT20 43" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
