Splashing My HE top load washer splashs product and water out of the top (lid) and comes out the front of the machine under the lid. I have had an eye burn from this. What is the problem? Shouldn't the lid be water tight?
  • necktie Jun 16, 2008
    Thank you Bob for responding. I have a new H.E. top loader washer. The washer is supposed to judge the water level with each load. I have not put clothes in with water already in the tub. They tell you to use javex for maintenance. I have not done this because of the leaking. If this is the way it operates. I will have no recourse but to trash the machine. With my eye burn already, I am not going to take another chance. Could the machine be faulty.
  • necktie Jun 17, 2008
    Thank you Bob for the comment. Javex is a cleaning agent like clorox ( I guess). It is used for buildup of mildew. I cannot tell how high the water comes in because the lid is locked down when the machine starts.. It is an HE. machine using only water shoot-up. When I burned my eyes, there was a Javex or clorox or clorine smell in the air. I was using non-perfume HE Tide and non-perfume Downy. I am beginning to think that this would always happen, but I will try to find an answer from the manufacturer. Your comments have been very useful. Thanks again.
  • 833 Answers
Most top loaders are not water tight. They are splash resistant. I'm guessing that your water level is too high or you are loading your clothing into a machine that is already full of water raising the water level excessively.
If you allow your machine to fill with no clothes for test purposes, you should see a level about 3 inches below the top of the agitator. If it is higher than that, I suggest that you investigate why or use a lower water setting.
Posted on Jun 16, 2008
  • Robert Hirst Jun 17, 2008
    Necktie....not sure what javex is. I'm in the US. I doubt you need it unless you have a specific water condition causing scale buildup. How high did that water come up before it stopped running in? If the unit is new, get the manufacturer involved. The water limit switch could be faulty...an easy fix.
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Water collecting under the machine during a wash which is not due to a leak
I had one that would spin water over the top of the drum during the wash cycle once, even with low water level. There are actually brake shoes/pads that add resistance, so the agitate won't over spin before it changes direction. I don't remember them being too difficult to install.
May 03, 2014 | Speed Queen AWS52NW Top Load Washer
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Replace splash guard FAV6800AWW
Disconnect power supply to the washer then insert a plastic putty knife or similar tool in line with the lid seam, as shown, and push in to release the catches on the left and right side.
Once the catches are released, lift the front of the top cover and tilt toward the rear of the washer. Unsnap the splash guard starting in the lower right corner, as shown, then work around the perimeter until the guard is totally free.
Follow the removal steps in reverse order when installing the new splash guard.
Jun 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Top load whirlpool washer model LSQ9544KQO leaking small amount
more likely from a hose........need lid off and a good torch
cheers
Aug 03, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water splash sheild ineffective
My machine may be a different model, but seems to have similar problems. I resolved this by: a) making sure the splash shield is fastened correctly at all points round the tub (it worked loose) b) as a temporary fix reversed the foam gasket inside the splashshield until I get a new one
Aug 22, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
