I dont no how to work them,ive switched it on at the wall and put both the input and output dials onto max.do they ususally take over a day to gather heat as mine had no heat in it at all lastnight.theres nothing wrong with the heater itself its just that i need some idea on how they work.
  • 81 Answers
What kind of air con are we talking about. a box air con in your window ? whens the last time you have seen it heating? does it cool. it should take 1 min for the fan to start 90seconds for heat/cool air to come out
Posted on Nov 09, 2010
My Hitachi 35L 8500 stopped working??
Check and replace the damaged component/s at its SMPS circuit.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Feb 04, 2016 | Hitachi Televison & Video
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
My sinotec has power but it dnt wnt to switch over to show piture plz help
Feb 15, 2015 | Televison & Video
Im trying to figure put a constant power supply for powering several servos.
I buy wall chargers that match needed voltage cut the cord right at the plug for whatever it was used with before and shoulder them in. Besides that but a transformer and wire into your house permenatly. Or wire the transformer to the male end of an extension cord and just plug it in. Make sure your inputs and outputs are all correct. 11_15_2013_2_57_21_pm.png
Oct 28, 2013 | Electronics - Others
My NAD C350 plays very faintly. when I turn the volume dial to the max position, I can bearly hear the music. I can hear properly from earphones output. Thanks
Take care. First put the volume down complete. Then unplug the head phone and than try to raise the volume. Could be the headphone connector does not switch through correct. Could be the connections between the pre and power amp are not in place or not proper pushed in?
Always take care when working with amplifiers. When switching them on with volume to max, you easy can kill your speakers. Also when disconnecting the headphones on full power kan damage the loudspeakers.
Aug 29, 2013 | NAD Audio Players & Recorders
Not printing or receiving fax
Is the problem not printing received faxes and cannot send faxes? Did this problem start suddenly? Has it ever worked?
My first suspicion is the drivers for the fax portion of your device. Do you have the Kyocera diagnostics for your device? That would tell you quickly. If you can print from the PC, Scan to the printer that would isolate the problem to the fax portion.
In that case, check all the wires from the phone jack on the wall to the fax and any output lines from the fax to the wall. Are they in good repair? Is your phone line connected? Do you have dial tone on that phone line? The other place to check is the phone line input/output jacks on the back. Are they switched? The normal connection is from the phone jack on the was to the input jack on the device. Then from the output jack on the device to the telephone.
Jun 25, 2012 | Kyocera Mita KM-1650 All-In-One Printer
I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the 1611..........Johnmoondancer@hotmail.com
Mar 06, 2011 | Audio Players & Recorders
Hello I have a Unidare night store heater that
ive just bought a house with unidare night stoarge heaters and one of mine hasnt worked - i found something on a site that said this:
"My Unidare storage heaters have a fused link (may be the wrong term ) that melt ever few years. Are you able to unscrew the top of the unit and look ( all turned off etc ) -A Fused link looks like an inch long piece of 5 mm solder - if yours has melted it will probably be in silver balls/blobs - replacing is easy if you have got to them."
so this could be why they arent working...
at night set the input to high (6) and output to about 3...in the morning set the output to 2/3 so a bit of heat will be released when at work, and then when you come in set the output to 6 (max)....should work! ive only just learnt what to do but ive they arent great!
Nov 03, 2009 | Heating & Cooling
How to work a slimline creda nitestore heater
I have one of these heaters as well. The input/output dials are thermostats.
The higher the input dial is set, the more power the heater draws during its charge cycle (ie the "on" period that is set on your time panel). Which means a higher daily ration of heat, and a bigger power bill.
The higher the output dial is set, the more quickly the heater lets the stored heat out. So the highest setting would give you most of your daily ration of heat during the "on" period but less heat for the "off period... while the lowest setting would give you a relatively constant heat output throughout the day.
May 20, 2009 | Heating & Cooling
Volume turned to MAX for almost no sound from record player
You will need to purchase small box that converts your phono magnetic cartridge level output to a higher line input level before it goes into the TV input jack. Radio Shack used to sell a small amp for about $20 that was made just for that purpose and was called a stereo pre-amplifier and was model number SPA-50 and it plugged into the standard wall outlet to get power. Back in the "old" days when phono magnetic cartridges first became popular some of the older home stereos had only the ceramic phono style inputs (or an aux. input) which were about the same input level as a tape input or aux. input (or TV input) and so you would have to use one of these adapters to boost the newer magnetic cartridge signal up to the same level as a ceramic cartridge in order to use a new style of phono. This will fix your problem if you can find one at Radio Shack or some other place, perhaps on the internet. Hope this helps you.
Nov 20, 2007 | Sony STR-DG510 Receiver
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
