Question about AEG Ovens
Competence 5208B, fan oven blows cold and won't heat up, ordinary (non fan) oven does get hot
  • normanalewis Nov 15, 2010
    Good reply, thanks, the element is indeed broken, corroded thru on a quarter of its diameter. Now I need to know how to change it please, is it an easy job?
    Norman.
  • AEG Master
  • 3,463 Answers
Hi.
You need to replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Posted on Nov 09, 2010
  • 2 more comments
  • Barry Coates
    Barry Coates Nov 15, 2010
    Yes, a very easy job to do, just undo the 2 screws securing element to rear wall of oven, ease it forward and detach the 2 leads, and earth wire if there is one
    Fit leads to new element , refit element.
  • normanalewis Nov 19, 2010
    Hi, new element has arrived and as you say, undo the two screws and that is it basically. However, my oven is fitted into a kitchen unit, so I guess the whole unit has to come away from the fitted kitchen. Therefore I guess I need the fitter to come and do it as cannot imagine that I can remove the whole cooker from the frame or whatever it is in.
  • Barry Coates
    Barry Coates Nov 19, 2010
    Hi.
    You should not need to get a fitter to do the job for you.
    Once you have undone the screws, just pull the element towards you, and it it will come away from the rear panel.
    The wires will still be attached, so carefully remove them and fit onto new element.
    You should not have any problem.
    Good luck.
    Hi again,
    Unfortunately the screws are behind the panel, oh that it would be so easy. With a free standing cooker no problem, just pull it forward, but as already stated, mine is built in, but as ever, your comments are welcome and much appreciated.
    Norman.
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
Ec600 dodlm model the fan oven is only blowing cold air
check for blown oven fuse. replace heating element in the oven
Jan 30, 2015 | Ovens
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 | Candy Ovens
When baking lots of hot air blowing from top vent
It is a good thing that the heat blows out. Electric oven didnt have anywhere to vent so the cpu boards got hot and burned up. So to correct this problem there is a little fan that blow out the heat so the cpu board doesnt over heat. thats all.. no worries mate
Mar 25, 2010 | KitchenAid Architect Series KEMC308KSS...
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Ovens Logo
165 people viewed this question
Top AEG Ovens Experts
Steve Allison
Steve Allison
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
