Question about Lexmark X646e All-In-One Laser Printer
Lexmark X646e All-In-One Laser Printer Paper jam duplex Out lexmark used to print duplex but after techs took it apart and cleaned it, it doesn't print any more. The paper prints one side and the gets stuck half way out. it does not print the other side. We use PSPprint and it used to work untill they worked on it. Now they dont know what the problem is, and keep ons changing settings, although i am convinced its not a settings problem. can you help or give advice on how to fix it?
Open left door. Remove screw covering the white plastic cover. Observed the white gear that you will now see. Make sure that it is not broken. If this gear is broken, you will not be able to duplex. What is the full code numerical code of the error?
Posted on Nov 22, 2010
I have a Lexmark Platinum Pro905 all-in-one printer.
Dust and dirt are usually the main causes. Using compressed air, gently blow out along the underside and inside of your printer. Please be very careful not to hit the print head as they are very easily damaged and Lexmark isn't making any new ones any longer. Sometimes, little pieces of paper can get in there as well. If you use the 'Clean heads" option on your printer, you will use an exorbident amount of ink! I was amazed my first few times (I couldn't believe it so, naturally, I had to check it again!).
Apr 25, 2017 | Lexmark Office Equipment & Supplies
Lexmark x646e turn off after 3 mins
Try updating the firmware of your printer: http://bit.ly/P8Ng6S
May 24, 2012 | Lexmark X646e All-In-One Laser Printer
Why is my lexmark x646e is printing with black lines
Debris or marks on the scanner glass can affect the quality of the scanned or copied documents. Please try to clean the flatbed. Please click on the link below for more details.
http://bitly.com/q9lAn0
If you need further assistance please contact Lexmark technical Support.
Aug 12, 2011 | Lexmark X646e All-In-One Laser Printer
My printer show in display paper jam in back door but there are not paper here. I took out the fuser unit and there not paper jam. thanks
There are two flags on the back of the fuser, make sure the are moving properly and that the sensor itself has not been knocked off.
May 21, 2011 | Lexmark X646e Laser Printer
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
I have a lexmark pinter/fax model x646e, i do not have the manual. when i am trying to make copies it reads" 290.01 scanner jam, remove all originals from the scanner" but there is nothing stuck. i have...
This is a hardware issue. Maybe the sensor, the pick arm or the pick roller itself that's causing the problem. Here's an article on Repeated '290' Paper Jam Messages Occur When Using the Automatic Document Feed (ADF) on a Lexmark X64x Series Printer. Just click on this link: http://bit.ly/clBsWr. If this doesn't help, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 26, 2010 | Lexmark X646e All-In-One Laser Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
Papaer jam "check duplex"
Here's an article in the Lexmark website on Paper Jams and the Printer Displays a 'Check Duplex' or a '23x' Type Paper Jam Message: Lexmark T650, T652, T654, or X65x Series Printers. Just click on this link: http://bit.ly/aqGjtK. Read the instructions thoroughly. Hope this helps but if you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 25, 2010 | Lexmark T652DTN MONO LASER PRINT Printer
My school's computer "Lexmark E323" has a paper jam and nobody knows how to fix it
hi!!!!try to open the duplexer at the back of your printer and see if there's a paper stock in the duplexer who cause a paper jam to your printer.
May 01, 2009 | Lexmark E323 Laser Printer
Lexmark X646e All-In-One Laser Printer Logo
384 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
