Question about Nokia N70 Cellular Phone
How to hold a call and look for a number from the contacts and to come back to the call?
    Guru:
  • 832 Answers
Hi there!
When you are in a call, check the following steps:
1. Press the Option Menu
2. Select the Hold (it will put on hold your current call)
3. You may go to the main menu and select Contacts
4. Search the number of your choice.
5. Select the unhold call
Hope it helps,
fossildude
Posted on Nov 09, 2010
How do I change my battery in my nixon 51-30chrono stainless watch
Where the back contacts the watch you'll discover a spot where the back doesn't completely contact the watch case. Slide a thin bladed knife in there to pry off the back. You may see a screw holding the battery down. A jewelers screw driver will be needed to loosen it. You will see a number on the battery. The replacement battery will have the same number on it or a series of numbers it's compatible with. Once the battery is out, replacing it is simple.
Jan 01, 2016 | Nixon Watches
How to assign speed dial numbers
hold the preferred number to which you want to assign the contact to and press the assign contact or add contact option
Jul 15, 2015 | Cell Phones
How do I contact kindle in uk ?
I've heard of these problems before but without knowing your exact model number just try pressing and holding the power button for a FULL 40 seconds. Ensure that it is not plugged into any power outlet or PC first. Hold it for 40 seconds. Time yourself. Better to go longer than not the full 40. Hope that helps. After you've done that, power it back up.
Kindle is made by Amazon so contact Amazon.co.uk
Feb 28, 2015 | Amazon Kindle
How do i unlock radio in chevy monte carlo tried the procedure no response
take radio out on the back is some numbers contact manufacturer give them the numbers and they will give you the code
Feb 09, 2015 | Cars & Trucks
Need the radio code for my 1996 honda accord special edition
if you dont have your radio code then we need to get your serial number, there 3 ways to get it.
* First try looking in your glove box for a sticker which will be a 7 or 8 digit number (your serial number) if its not there, then try this - With the radio off hold in buttons ' 1 ' and ' 6 ', while holding those in turn on the power button, that should give you your serial number,
* If that still dosnt work then you will have to pull the radio out of the dash and get the serial number off of the back of the radio.
* Once you have your serial number contact your local honda dealer and tell them your situation and they will be able to give you the code to unlock your radio.
Also, you will have to contact your Honda Dealer. The original selling dealer may have the code on file. If not you will have to remove the radio and get the serial number of the chassis. With this serial number, any Honda dealer can provide the correct code. There is no other way to unlock the radio than with that code.
Good lukc (remember rated this).
Jun 30, 2010 | 1996 Honda Accord
I can't dial out.
The Phone application on the BlackBerry smartphone automatically converts phone numbers that include letters into the associated numbers.
To key a phone number that contains letters, press the right Shift key or the Alt key and type. The letters appear on your screen, but the BlackBerry smartphone translates them into the appropriate numbers when the phone call is made.
For example, to call 1-877-BLK-BERR (1-877-255-2377) from your BlackBerry smartphone,
  1. Open the Phone application.
  2. Type 1877.
  3. Press and hold the Alt or right Shift key and type BLKBERR.
  4. Display the menu and select Call 1877BLKBERR or press Enter. When the phone number is dialed, the letters are converted to numbers on the screen.
  5. To end the phone call, hold down the Escape key.
To return to the Home screen from any other screen, press the End key.
To lock the device, set a password. Hold the * key.
To unlock the device, press the * key. Click Unlock. Type your password.
To lock the keyboard, hold the * key.
To unlock the keyboard, press the * key
To switch the input language, hold the Alt key and press the Enter key. Continue to hold the Alt key and select a language. Release the Alt key to switch to that language.
To switch back to your original input language, press the Alt key + the Enter key.
I hope this helps
Please remember to rate this solution.
Sep 21, 2008 | RIM BlackBerry Pearl 8100
7610 Gsm start up failed,contact retailer.
System might be damanged,
You can hard reset the phone (Factory Settings)
This will reinstall the operating system inside the phone back to how it first was.
(internal memory gets formatted then the rom reloads the os back)
(Solves all kinds of problems.)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
Try to make backups first.
You have been "Warned".
Best of Luck.
Jun 08, 2008 | Nokia 7610
Setting up a speed dial
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Sep 16, 2007 | Kyocera K10 Royale Cellular Phone
Nokia N70 Cellular Phone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
