Question about New World 70TC Electric Single Oven
I have just purchased a new electric cooker. The old one had three terminals in the back, one each for live, neutral and earth. The new one has three marked live, two marked neutral and one marked earth. I am not sure which terminals I should use for live and neutral, can you advise please. Thank you. Roger
  • New World Master
  • 3,463 Answers
Hi.
Live goes to live as normal earth to earth as normal, and the neutral is probably a comonj terminal, in other words it probably has a lnk joining the 2 neutrals together.
Posted on Nov 09, 2010
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
My terim cooker has 3 wires - black, blue and brown. Do you know which is live, negative and earth?
green or green and yellow is the ground (earth), blue is neutral, black and brown are both lives. this is the standard european wire color code since 2004. If it is older than that, black was used as a neutral, and blue as a live. very confusing.
Jul 21, 2011 | Ovens
Ive taken element out to replace with new but have forgotten the way the wires went back.there are three spade connections the earth is obvious but not the live and neutral
Hello Ian,
You can put the live and neutral on either of the outer terminals terminal. It really doesn't matter. It's the same principle as not needing to screw in a bayonet light bulb a certain way round. As long as the circuit is complete, it will work correctly.
To put it in the simplest terms, attach the earth wire to the shorter centre terminal with the live and neutral wires on the two outer terminals and job's a good 'un.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Apr 18, 2011 | Belling XOU252 Electric Single Oven
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
I need to wire up an electric cooker ,am unsure what wires go where as in live earth etc
White is neutral, green (or bare copper) is ground (earth), black is hot. If it's a 220-volt unit you will also have a red - it's another hot.
Nov 20, 2009 | Ovens
Apart from the main supply to the cooker terminals
So long as the earth is connected to the earth terminal, then there is no prob for you to worry about.
The normal twin and earth cable is adequate.
Please rate my comments.
Thankyou..
Mar 05, 2009 | Neff U1661 Double circotherm super...
Oven has 4 conductor power cable, moved to house with 3 conductor
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Sep 28, 2008 | Belling XOU174 Electric Single Oven
Installation guide - bosch hbn131250b
1. The screws seem to need a small hex screwdriver, but I managed to get my normal electrical screwdriver to fit - they are not too tight.
2. The wiring is straightforward - there is an earth position with no wire from the oven attached, marked with the standard earth sign, that should connect to your yellow/green wire. The other two connectors have either a blue (neutral) or a brown (live) wire attached to them - they should connect to your black (neutral in old money) or red (live) wires
Jan 27, 2008 | Ovens
Electrolux EOB5600 electrical fault?
goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Jan 06, 2008 | Electrolux EOB5600 Ultrafan Electric...
New World 70TC Electric Single Oven Logo
180 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
