Help me willtab guru man...Please.
I just changed the light hoping this would fix the problem. When theproblem first occurred, I could barely make out the picture, and it wasvery green and jumpy (but I could still see spider man on TV with the 5 big vertical lines). I called tech supportand they said unplug the TV and plug it in after about 5 minutes. I didthat and now it went from bad to worse. No picture at all. I have whiteand black static on the screen that also has a green tint. I have 5vertical evenly spaced lines. The big 3 inch lines consist of about 10skinny lines. I can put the TV on air-antenna, Satelite, DVD, NindendoWii, and the greenish static follows all components. When I hit "menu"on the TV remote, all menu options are crystal clear. Set-up, channel,sound, etc...all perfect picture...Just a problem with the actualpicture on all components. Please help if possible.
  • 1 more comment
  • Eatsolot
    Eatsolot Jun 18, 2008
    Thank you for the response.
    I have a 60" Samsung DLP HLR6167w
    I turned it on again last night and I found more details.
    The attached picture is what it looks like when it's on. It looks like that for 15 seconds then freezes. When it freezes I can't turn the TV off/on nor navigate through the TV's menu (it freezes also) Then the screen goes black like it's turned off. I look at the back of the TV and the light bulb seems to still be on.
  • Eatsolot
    I have a SAMSUNG DLP model HLR6167w
  • Eatsolot
    Eatsolot Jul 03, 2008
    Willtab is a genius!!!!!
    I tightned the monitor type cable and my TV had a perfect signal. I then moved the TV from the coffee table back to it's original location and the problem came back. At this point the cable was as tight on both ends as it would go. I guess I need to try and replace that cable and see what happens.
  • 1,030 Answers
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Posted on Jun 17, 2008
  • Willie Howell Jun 18, 2008
    Your picture indicates to me a dvi signal problem... the menu are generated in the light engine. There is a large cable between the signal and the light engine.. often called dvi... sort the hdmi cable. check to see if this is loose. usally has two screws much like a monitor cable....
My 2003 grand am's emergency flasher is clicking intermittantly and sporadically without being turned on. have replaced the flasher hazard switch/module, but it didn't fix the problem.
Hello! The Hazard Switch/Module connector has the following wires of interest...Pin G=Dark Blue (right side lights)...Pin F=Light Blue/Black (left side lights)...Pin H= Purple (flasher battery)...And Pin A=Black (ground)...In order for the lights to flash, without pressing the switch, Flasher Battery must be applied to Pins G and/or F...When the problem occurs are all external lights flashing or just one side? Visually inspect the connector for bent pins and the harness for bare or frayed wires...If you have a multimeter and a wee bit of experience using it; Set the ohm meter to X10 scale...Measure from Pin A (black wire) to the center of the negative battery post...Reading should be zero ohms or very close to it...Send results...
Nov 20, 2010 | 2003 Pontiac Grand Am
I have 1971 F100 problem! when i trun on my park lights or head lights my left break light gos out when i press on the break.
Hello! The Turn/Hazard Switch is defective...Replace switch...Let's check the vehicle grounding just to be sure...If you have a multimeter set in on the lowest ohm scale...Place one probe on the center of the negative battery post...The other probe to bare metal chassis...Record reading...Move probe from bare metal chassis to the engine block...
record reading...Send results...Guru.............Saailer
Aug 28, 2010 | 1981 Ford F 100
Bosch dishwaher Model # SHX46A does not display indicator lights and does not function in any mode. There is power to the on/off switch that works and power to the control panel. Other wise the unit is...
Having same problem, power to outlet, but unit is "dead", no lights, won't turn on. Unit is 6 yrs old and don't want to spend $100 for a repair man to tell me there is no hope....anyone else experience this?
Aug 12, 2010 | Bosch Dishwashers
My Sony KDF-60Xs955 rear projection has a blueish green tint on the screen. it is really noticable during darker scenes and is distoring the colors in other pictures. A tech came out and tried to adjust...
this is normally either a color calibration (easy) or a light adjustment(if burnt out very bad)
for the color calibration you want to go into your menu setting and look for the color calibration menu it should give you two cross hairs to align causing a different color yellow red is orange green is blue yellow and so on after ensuring all theese setting are correct your best bet is going to be taking it to or having a television repair man come to you to check the bulbs hopefully if just an adjustment needs to be made cost should be minimal unfortunately if a light is burnt out its usually cheaper to buy a new tv
hope this helps
please leave feedback
Apr 22, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Xbox 360 1022 error
yes its the hardware problem not with ur cables or something
hey please vote me man i want to be a guru i tell u some tips if u vote me
Mar 06, 2009 | Microsoft Xbox Console
Televison & Video Logo
308 people viewed this question
Top Televison & Video Experts
