Question about Mitsubishi Heating & Cooling
Evo 4 wiring diagram for air-cond control module
  • 62 Answers
SOURCE: Control Module WMA34
If my memory serves me well, the plugs/wires will only fit the correct spots on the module, and I believe there is a "jumper" on the original module, make sure you remove and install in the new module..Good Luck
RMK
Retired GE Technican
Posted on May 21, 2009
SOURCE: problems with low voltage control wiring turning on cond. unit
hooked up white wire from condensing unit to (c) on furnace control board and ( red ) wire from condenser to (y) on furnace control board and could not get 24 volts out goodman condenser ! there is 24volts coming out of transformer! also good fuse in control board!
Posted on Jun 23, 2009
  • 94 Answers
SOURCE: Please help me i need the Lighting Control Module diagram
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm1of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm2of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm3of3.gif
follow the three links for complete wiring diagram of lcm
Posted on Jun 30, 2009
emissionwiz
  • 79189 Answers
SOURCE: cant find air cond,clutch relay
IT IS LOCATED IN THE POWER DISTRIBUTION BOX UNDER THE HOOD, IT SHOULD BE MARKED IT IS A 60 AMP MAXI FUSE.
Posted on Jul 13, 2009
saailer
  • 1871 Answers
SOURCE: I need wiring diagram for
Hello! Schematic will be on it's way shortly...Saailer
Posted on Sep 13, 2011
Need to see the wiring diagram for dean evo xm
Here's the diagram.
You probably don't even have 4 wires from each pickup, because the middle ones are already connected.
Jan 25, 2013 | Dean Evo Xm Electric Guitar
Rear cylinder blowing cold air out the exhaust on 1991 flhs with evo
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the negative cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below.
Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Oct 30, 2012 | Harley Davidson Motorcycles
I need to know what wiring diagram to use for SSZ140421 Cond with AEPF426016 handler with HKR15C strips.
The AEPF number is for an Amana air handler. I have a manual for this number. Send me an email address and I can forward it to you. Manual has diagram.
Oct 06, 2010 | Goodman CLQ36AR49 Air Conditioner
1992 heritage softail 80 Evo good start up, good take off at passing on highway speeds 65-70 starts sputterring
Hi Eduardo_hand, and the usual suspects are:
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
11. Damaged carburetor.
For a prime suspect please visit website below and good luck:
Aug 24, 2010 | Harley Davidson FLSTC - FLSTCI Heritage...
IM IN NEED OF A FUSE BOX DIAGRAM FOR A 1999 LINCOLN NAVIGATOR
go to the ford lincoln mercury website and enter you year, make, model of your vehicle. It will let you download a pdf version to your computer. then open the document and go to page 135. this is free don't pay for something you shouldn't, you already got the vehicle. this is just information. Fuse Location,Fuse Amp,Description
1) 25A Audio
2) 5A Clock, Overhead Trip Computer, Electronic
Automatic Temperature Control (EATC),
Powertrain Control Module (PCM), Cluster
3) 20A Cigar Lighter, OBD-II Scan Tool Connector
4) 15A Autolamp Module, Remote Entry Module,
Mirrors, Memory Module, Adjustable
Pedals, Air Suspension Switch
5) 15A AC Clutch Relay, Speed Control Module,
Reverse Lamp, EVO Module, Climate Mode
6 5A Cluster, Overhead Trip Computer, Compass,
Steering Sensor, Brake Shift Interlock
Solenoid, Air Suspension Module, GEM
Module
7 5A Aux A/C Blower Relay, Console Blower
8 5A Radio, Remote Entry Module, Cell Phone,
Clock, GEM Module
9 — Not Used
10 — Not Used
11 30A Front Washer Pump Relay, Wiper Run/Park
Relay, Wiper Hi/LO Relay, Windshield Wiper
Motor, Rear Washer Pump Relay
12 — Not Used
13 20A Stop Lamp Switch (Lamps), Turn/Hazard
Flasher, Speed Control Module
14 15A Rear Wipers, Running Board Lamps,
Battery Saver Relay, Interior Lamp Relay,
Accessory Delay Relay (Power Windows,
Flip Windows, Audio)
15 5A Stop Lamp Switch, (Speed Control, Brake
Shift Interlock, ABS, PCM Module Inputs),
GEM Module
16 20A Headlamps (Hi Beams), Cluster (Hi Beam
Indicator)
17 10A Heated Mirrors/Rear Window Defroster
Indicator
18 5A Instrument Illumination (Dimmer Switch
Power), Clock (Dimmer)
19 — Not Used
20 5A Audio, Four Wheel Air Suspension (4WAS)
Module, Memory Module, GEM Module,
Digital Transmission Range Selector
21 15A Starter Relay, Fuse 20
22 10A Air Bag Module
23 10A Electrochromic Mirror, Aux A/C, Heated
Seats, Trailer Tow Battery Charge,
Turn/Hazard Flasher, Console Blower Door
Actuator
24 10A Climate Mode Switch (Blower Relay),
EATC (via fuse 7), EATC Blower Relay
25 5A 4 Wheel Anti-Lock Brake System (4WABS)
Module
26 10A Right Side Low Beam Headlamp
27 5A Foglamp Relay and Foglamp Indicator
28 10A Left Side Low Beam Headlamp
29 5A Autolamp Module, Transmission Overdrive
Control Switch
30 30A Passive Anti Theft Transceiver, Cluster,
Ignition Coils, Powertrain Control Module
Relay
31 10A Rear Integrated Control Panel (Audio), CD
Player, Cell Phone
Relay 1 — Interior Lamp Relay
Relay 2 — Battery Saver Relay
Relay 3 — Rear Window Defroster Relay
Relay 4 — One Touch Down Window Relay
Relay 5 — ACC Delay Relay
hope this helps.
Jun 16, 2010 | 1999 Lincoln Navigator
Installing new furnace with two zones
You will need a control to operate motorized zone dampers. In the ductwork, you will install a damper in each line going into the area you want zoned. If you have air conditioning you will also require a barometric relief damper that allows air to pass thru the ductwork and not restrict air over your A/C coil. Common controls are made by Honeywell and EWC.
If you already have the control module, you will run two or three (low voltage) wires from each motorized damper back to the control. Your thermostat wires (also low voltage) will run from each thermostat to the control module and connect to a zone relay. Match each zone by number. You will need to run power to the control module that will provide power to the thermostats as well as the motorized damper. Check on the reverse side of the control module and/or check on the web to find the wiring diagram.
Nov 21, 2008 | Goodman GMS90703BXA Heater
Split AC install
1. mind it - its a very simple installation
2. connect suction (or big cu. dia tube) connection to cond. unit (outdoor unit) big valve.
3. same way - liquid conn.(less dia tube) to small valve (liquid valve) in outdoor unit.
tight flare nut properly
4 provide power to indoor & run the same wire to cond. unit , you must hv got the ins. kit with wires and cu. tubes.
5. or read wiring diagram given of units for wire.
connect as per wiring dig. provided.
ravi
Jan 30, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
100 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
