Question about Vizio VX37L Television
My 37" vizio will light
  • 4,889 Answers
Does the tv click on when powered up?
Posted on Nov 09, 2010
My tv only turns on and the vizio logo lights up but there is not picture or sound. I contacted vizio support and was told it was a "backlight". When I contacted a tv repair service they told me...
These tvs problems 90% of the time are a dying and dead capacitors parts components on the tv power suply board.That the board where the power a/c cord plug in to it.10% it could be the main tv Tuner signal board dies alone by itself or together with the tv power supply board too.Tv have dying or dead LCD inverter board 1 or 2 long inverter boards help tv screen panel to have a backlight to the tv 90% tv still sound picture flashes a few sec. before it gose all together than have audio of the tv left only.At first glance problems tv could determine problems 50/50 of the times,but the tvs shops are correct could be any of these eclectronics boards on the tvs could died any of it boards to causes tvs to malfunctions.
Jul 25, 2011 | Vizio M370VT 37 in. LCD TV
I have a vizio vu37l tv..about 2 years old. Last night on its own it started switching to av1...comp...hdmi...all by itself..it even shut itself off. It also switched this morning....why is it doing this...
Vizio Has a big issue with all models working with each other, if either you have another vizio product in your home or a close neighbor, the remote signal is probably reaching your TV,
Jul 06, 2011 | Vizio VU37L 37 in. LCD TV
Suddenly no picture only a black screen.The tv has power the little vizio turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv...
Look through the ventilation slits at the back of the TV with the room lights out. If you do not see white light light bleeding through the back, you have a back light failure. It could be the inverter circuit which lights up the CCFL ( cold cathode fluorescent lamp ). You will need professional help to replace it and could cost you about 70 to 100 $ to fix.
Jul 06, 2011 | Vizio VOJ370F 37 in. LCD TV
My new vizio m370nv does not permit adjustment of the backlight % as the manual suggests should be available to me, even under "custom". It also allows for ajustment of contrast, brightness,...
Often manufactures will tie backlight adjustment in with the brightness, You might want to changed the brightness to your desired luminosity and then correct the picture with contrast to your liking.
Jan 19, 2011 | Vizio M370NV 37 in. LCD TV
I have a mfg date 2007 Vizio VW37L HDTV10A turned on and there is sound but not picture
This can happen. are the lights on? if not, it most likely id the power source inside the tv itself. make sure your wall outlets are working properly as well, but if they are, then you want to get you tv fixed. this can be a relatively low cost repair, but shop around
Apr 18, 2010 | Vizio VW37L 37 in. LCD TV
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
Feb 13, 2010 | Vizio VW37L 37 in. LCD HDTV
The TV has red and green lines, I touched the
you willl need an LCD panel replaced the buzzing sound you hear is the broken floresent bulbs arching
Nov 30, 2009 | Vizio VW37L 37 in. LCD TV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Vizio 37 inch plasma tv changing inputs all by itself
it sounds like you have a glitch in your tv. i would hope that you have the warranrty for it. and i would contact vizio right away and tell them about your problem and they will have to fix the issue. hope this helps you.
happy holidays,
tom
Dec 17, 2008 | Vizio L37 Television
TV problem
any luck? might 37" vizio just had this problem, all of a sudden no picture sound just fine, I call vizio and they say could be motherboard, do I bother fixing this, or just get a new one?
Nov 16, 2007 | Vizio L37 Television
Vizio VX37L Television Logo
130 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
