Question about Cell Phones
Metal slug 4 unlocked - Cell Phones
    President:
  • 1,118 Answers
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Posted on Nov 09, 2010
Unlock car door without keys
no year.
the metal key must work , metal keys work, so car on fire you can get kids out. (by law)
you saying no metal keys too, not just lost fob parts. RKE.
car came with 2 RKE keys, but no year stated so..
what does without keys mean?
dead fobs or no metal keys at all. or all 4 parts missing.
on mine i have 4 RKE fobs and 2 metal keys , for IN CASE>
if no metal keys, call the locksmith he can make one.
Jul 07, 2013 | Jeep Commander Cars & Trucks
Infinite ammo and infinite life
There are currently not cheats for Infinite ammo or life. Unfortunately there aren't any "cheat codes" for this game, but there is an alternate ending. In the end when defeat the final boss, you must run from explosions. If you let the explosions kill you, you will get an alternate ending.
May 04, 2011 | SNK Metal Slug 4 & 5 Combo for PlayStation...
Cheats
Gain Complete Achievement
  • A golden level sign is a badge of honor showing the player they have completed an in-game level to the highest completion standard. It is a graphic that sits above the level select graphic. To have the golden level complete sign hang over every game level, players must collect every available item and rescue every prisoner in the level during one play through. A good tip is to use the x-ray scan card to more easily find all the prisoners and collectibles.
  • All Boss Cards
  • The way to achieve a boss card is to destroy the boss the player is fighting as quickly as possible. If the player defeats the boss quickly, a onscreen message will pop up informing the player they succeeded in getting a boss card for that boss.
    The best way to do this is to make sure the in-game character is equipped with lots of grenades and a special weapon. On the fourth boss, use the flame shot. Try to use the Metal Slug if applicable. Players can use the Metal Slug for the second, third and final bosses.
  • Unlock the Extra Dungeon Mission
  • During the fifth mission, collect the dungeon card. The card is located in level five, section three. In Metal Slug Advance, players can take different paths to the end of a level. To achieve the dungeon card, take the top path directly after the first playable screen of level five, section three. Then, take the top path again at the next opportunity to choose a path. This is a dead end. Kill any existing enemies at the dead end and pick up the dungeon card collectible. Head back towards the previous screen and finish the level. Once the player has completed the fifth mission and collected the dungeon card during play, exit to the mission select screen. In the upper left hand corner will be a selectable extra mission called "Dungeon."
  • http://www.cheatgenius.com/gameboy-advance-cheats/metal-slug-advance-cheats/
    you can also check the above link..if this helped please vote for me.. good day to you
    Dec 23, 2010 | SNK Metal Slug Advance for Game Boy...
    Need to change FM frequency steps on Yamaha RX-495 Receiver
    I don't know how to change the tuning step from .2 Mhz to .1 Mhz, but whatever you do - don't adjust those tunable slugs! If you are told to - I would be very suspect of any procedure that says you must. Those types of coils are adjusted by a threaded iron core that when turned by the slot on top, either raise up from or slide down into the coil. Furthermore, use of a metal screwdriver is a big no-no to make those adjustments. Specially made fiberglass tweaker tools are used to adjust or tune these iron slugs, and often require special equipment (o-scope, DMM, etc) or other specific detailed procedure for proper setup. Fiberglass is used as it does not interact with the iron slug like a metal screwdriver would (appearing as more metal) by affecting the magnetic field of the coil. It has nothing to due with electric shock protection. Good luck!
    Jul 01, 2010 | Yamaha RX-495 2 Channels Receiver
    Lsb its off frcwense but upr and am are fine
    Adjust L21 WITH A NON METALIC ALIGNMENT TOOL THAT FITS INTO THE L21 SLUG to get it on frequency. IF YOU USE A METALIC TOOL, THE FREQUENCY WILL CHANGE WHEN YOU REMOVE THE TOOL. IF YOU TRY TO USE A TOOL THAT IS NOT THE CORRECT TOOL, YOU COULD DAMAGE THE SLUG AND END UP WITH A LARGER HEADACHE THAN YOU HAVE NOW..
    Apr 08, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
    Out of frecuency magnum s9
    If you have a GOOD frequency counter (not the in-line coaxial type), connect the probe to TP3 (It's the top bare lead on R74/Resistor 74)
    Adjust L19 for AM measurement of 16.2700 MHz,
    L20 for USB Measurement of 16.2725 MHz,
    L21 for LSB measurement of 16.2675 MHz.
    All 3 of These measurements are + or - 20 Hz
    BE SURE TO USE A NON METALIC TOOL! IF YOU DON'T, THE FREQUENCY WILL CHANGE WHEN YOU TAKE THE TOOL AWAY FROM THE TUNING SLUG. ALSO, USE THE CORRECT TOOL!
    IF YOU BREK THE TUNING SLUG(s), You'll be in need of someone to replace it/them. In the long run, it may be better to pay someone to re-align the radio rather than risk breaking anything.
    Apr 06, 2010 | Magnum S9 Base CB Radio
    ERROR 80020148 i own PSP-1001 with fw 5.00 m33-4 i am able to some of the cso games like nfs shift,tigerwoods pga-10,virtua tennis-3 bt few like fifa 10,smackdown2010,metal slug etc.. show the error 'game...
    hold the right shoulder button and turn the system on. it will go into the recovery menu. select configuration and goto umd mode. it will say normal UMD required. press X and it will change to M33 driver. now select back and then exit. system will restart. ENJOY!!!!
    Jan 03, 2010 | Sony PlayStation Portable (PSP) Slim...
    Can't remove the metal partition so that I can install a CD drive and a floppy drive. How does it come out ????
    Put a straight screwdriver in the slot of the center of the metal and move it up and down untill you break the off metal slug. then remove it and throw it away.
    Apr 09, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
    Removing metal slug to install an optical drive on an Acer deskto
    It will have to be bent until the metal gives. It is like those old toys that come in the grid that you have to bend and snap off.
    Cell Phones Logo
    98 people viewed this question
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
