Question about Seagate 25PK 160GB ST3160215AS SATA 7200 RPM 2MB 3.5IN 160 GB SATA Hard Drive
The hard disk not detect in my compter - Seagate 25PK 160GB ST3160215AS SATA 7200 RPM 2MB 3.5IN 160 GB SATA Hard Drive
  • 386 Answers
Hi Good day!! try to re-plug the sata cable and power adaptor of your hard disk and see if it is detected if not try to replace the sata cable. please reply if you have a question i will help you more.
Thank you for using FixYa
Posted on Nov 09, 2010
Bios cant read a 500GB HD
p4vm800 fsb mb solution- format hard disk in another compter and install window (os) on your hard disk .
connect with your motherboard ,turn on computer press bios entering key ( f2 or del ) . after entering the bios set up set as defalt . install window (os).
Aug 18, 2011 | Asrock P4VM800 Motherboard
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
Disk I/O error Replace The disk, and press any key
Its the problem with your Hard disk. Try to boot from xp cd and install a new copy. you will get error on installing if Hard disk is damaged. then you have to replace with new one
Apr 05, 2009 | Computers & Internet
Wont hook up to my compter
contol panel then add hardware then auto detect or installation disk
Apr 05, 2009 | Toys
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Ibm hard disk not detected
do u want to install the hard disk or do u want to setup raid? getting the hard drive to be detected has nothing to do with setting up RAID.
Dec 24, 2007 | ASUS Intel 440BX Chipset CUBX-L...
Seagate 25PK 160GB ST3160215AS SATA 7200 RPM 2MB 3.5IN 160 GB SATA Hard Drive Logo
133 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
