Question about Canon imageRUNNER C3220 Color Copier
How to install canon 3220 to the network for printing
Hello ,actually its a very easy way to install canon 3220 to a network just download the driver from canon official site :software.canon-Europe.com
go to printers and faxes add printer press local then next choose create port choose stranded tcp/ip write down the same ip of the copier then press next ,choose have disk and specify where the file u download it from the site and after that choose from the menu canon clc3220 c1pcl5 then press ok so now the printer driver is defined. now at the other side (photo copier ) press * system management network settings choose TCP/IP and give the machine IP turn off and the on the machine to save the changes .now the machine is connected through the network :) for more assistant t here is my email mramlawi@gmail.com regards :)
Posted on Dec 14, 2010
How can you print the Configuration Page on a Canon 3220? We are trying to find out what the IP address of the printer is.
For a Canon C3220:
- Choose the Printer tab on the touch screen - Under Printer Status, go to Settings - Go to Functions - Go to Print Pages - Select Configuration
The configuration page will print out. Thanks for using FixYa!
For configuration page instructions on other copiers, printers, and fax machines, check out the How to print config pages blog.
May 03, 2011 | Canon imageRUNNER C3220 Color Copier
IRC 3220 Color Copier when printing pdf files is very slow. A 2 page document takes 2 hours to print. please help.
Hello pd.
I suggest you remove and re-install your print driver and make sure you install the CANON UFRII print driver available at the Canon web site. Also, Adobe 8.0 has a known problem with this and you can go to their website and they have a patch for this problem, I hope this helps.
Feb 16, 2011 | Canon imageRUNNER C3220 Color Copier
3220: there is no network in my nokia 3220 handset when ...
i have 3220 with network problem any body send me jumper diagram
May 05, 2010 | Nokia 3220
Conect to network
you have to setup in printer menu option
network settings
-> TCP/IP settings
-> IP address
-> subnet mask
-> Gateway address
and ping the ip of pirnter form pc and install the driver .
Jan 28, 2010 | Office Equipment & Supplies
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
I have installed the drivers for both my canon imagerunner 3220 and my 3300 but i still cannot print to it or scan from it. I have the network cables connected... I can ping it do i have the right...
Enter the device IP into your web browser. This shoudl load its web management interface. If it does not, you have an IP connectivity issue. You must power cycle the unit after changing IP settings.
press additional functions, report settings, network, user data list, yes. Check to see if DHCP is enabled. If it is, the IP displayed in the report may not be correct. DHCP should be off in most cases. Verify IP shown here.
Double check for link lights on the network cable.
Jan 12, 2009 | Canon imageRUNNER C3220 Color Copier
How to print and staple landscape using Canon 3220
HI
You go to you printer properties(you will find it if you right click on the printer driver under printers and faxes in the controll panel),select printing prefrences,page setup,there is a option for landscape printing.Next to page setup is the finnisher settings,select the stapler option.
Nov 11, 2008 | Canon imageRUNNER C3220 Color Copier
Canon IR C3220 cannot print multiple pages..ONLY able to print one page
The answer depends upon the printer controller that your 3220 has. There are at least 3 controllers & probably twice as many versions for the assorted printer controllers. The key is do you have a Fiery (Little white box hanging on the back) or does the network connect directly into the NIC on the upper left corner of the copier. Drivers with -C1  or  -C2 connote a Fiery printer driver. I would advise using the PS drivers if this is the case as the Fiery is much better at PS than PCL. Another way to tell if Fiery is on copier is scroll to right on LCD panel & see if there is a "Printer" screen. If so you can go in to "functions" "Print Pages" & print a "Configuration" page. this will show you the network ip#. Put the # in your web browser (no http:// etc needed) & you can download the correct drivers for Mac / PC right from the device. If no Fiery is on the device stick with PCL5C drivers as they are usually the best for Canon PDL board print controllers.
Sep 02, 2008 | Canon imageRUNNER C3220 Color Copier
Canon iR 3220 printer problem with PDF files
Sound like a driver issue, reinstall and check that it is correct one.
Nov 09, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3220 Color Copier Logo
882 people viewed this question
old marine
old marine
