Question about Microsoft Xbox 360 Console
Xbox 360 dvd rom led voltage adjust.
Can you tell me step by step how to adjust the voltage on the led to get it in proper calibration for the dvd rom drive?
  • 14 Answers
I would assume this is what you're talking about. It's easier to buy a new laser off ebay though.
Posted on Nov 15, 2008
I cannot play most of the games due to region code....I have an Xbox 360 pal as well as Xbox 360 ntsc console....the latter has burnt up but its DVD ROM is alright....if i change the DVD ROM of pal to ntsc...
Interesting question.
Yes you can do that but you don't need to replace the DVD Rom.
You need 2 tools: PAL-to-NTSC converter box and a voltage converter. Don't know where to buy these though. Sorry.
If you manage to get those tools then you need to refer to a guide. Here's a detailed one from e How:
Click here for the guide.
Hope you get it working.
May 19, 2011 | Video Game Consoles & Games
My 360 is not reading the disk what can i do?
There are a couple of steps you can take when your 360 isn't reading your DVD-Rom.
First off, try another game, if it reads it then your 360 is working properly. Your game on the other hand may have scratched which need to be cleaned. If it's cracked, there's nothing you can do.
If it's not reading any other game disk, then you should try airing out the dust in your 360. If that doesn't work you can try cleaning the lends. Here's some information from eHow in regards to cleaning the lens. I like recommending eHow because it provides simple, easy to follow, step-by-step instructions for situations which may seem difficult:
Jan 04, 2011 | Microsoft Xbox 360 Console
My xbox 360 says play dvd but i put in halo 3 which is a video game
Is your DVD-ROM the original one that was in it when it was purchased? If not, then there's your problem. If you replace it with another ROM from a different 360, or with an after-market 360 ROM, then it will only play movies and not the games. It requires you to hack your 360 to get the new ROM to work properly, and that's alot of stuff to do. I think that according to the rules of this website I'm not allowed to post info about how to hack & crack things. If your DVD-ROM is the original one, then maybe your need to update your firmware and even run a cleaning disc in your 360 to get it to work right. If that doesn't work, then you have the option of replacing your ROM yourself and finding the hacks to make it work right, or you can pay Microsoft about $100 to fix it for you.
Apr 27, 2010 | Microsoft Xbox 360 Console
Open tray error and thensome.
Unreadable disc errors or open tray errors are commonly fixed by pot calibration or laser assembly replacement. Pot calibration is the cheaper of the two, and if it fails and burns out the laser, well, replacing the laser would be the next step anyway.
You shouldn't calibrate the pot without an ohms reader simply because you can burn out the laser, but you CAN wing it. I'd advise doing some searching on DVD Drive pot calibration for the Xbox 360, simply because I don't know which drive you have so I can't help identify anything for you.
I will say you have to disassemble it down until you see the motherboard, take out the DVD drive, open it up, and then calibrate the pot with a very small screwdriver. The location of the pot depends on your drive. If this fails, then buy a new laser assembly and replace it in the drive.
p.s. pot calibration is fancy terminology. There are basically 2 "screws" inside the drive, 1 pot is the DVD/games, and the other is CD. You'll want to very slightly tweak the DVD/games pot until it works, testing with each tweak. You barely need to adjust this "screw" for a significant change to happen. Also, always test with a DVD and then a game. It will read a DVD before a game.
Apr 09, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont play my games
if it tells you the disc is unreadable then the laser maybe bad or dirty.
try a cd lens cleaner and see if it solves the problem. if it doesn't then your dvd rom will need to be replaced
Apr 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 Rom to pc
no u cant the dvd rom for the 360 is coded for that board only ....and i have a way to fix the three rings of death
Nov 06, 2008 | Microsoft Xbox 360 Console
Xbox 360
The dvd rom drive is probably not functioning properly maby try to use the drive out of you friends 360 or have your drive tested.
Jan 06, 2008 | Microsoft Xbox 360 Console
Xbox 360
First point is you need to extract the firmware from the old original (very important) drive which involves opening up the xbox 360. there are many guides online which show how to do this. Try and select tutorials where there are nice video tutorials which you can pause and do at your own pace on almost anything xbox 360 related. To explain this in full detail here would take an eternity and i find that video tutorials work best. I know that I'm sending you to another site but trust me that site is a goldmine of information and well put together too.
Should mention that within thisa firmware lies the dvd key if you follow the video tutorials and successfully extract the dvd key then i suggest you make many copies of this key called (orig.bin) if you lose it then your xbox 360 £200 odd pound machine becomes a very expensive dvd player.
Dec 22, 2007 | Microsoft Xbox 360 Console
Dvd rom for xbox 360
where did you buy it from?
nothing like customer service!
what dvd player did you get?|#4
select dvd firmware guide
Dec 21, 2007 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
639 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
