The fan is making some annoying noise and it gets so hot.
  • 121 Answers
Check if there is nothing in its way else there might be a broken fin making it unbalanced. if broken its best to change it altogether
Posted on Nov 09, 2010
Fan making annoying sound
Electro-mechanical fans make noise when wear and tear create sufficient gaps between the mating surfaces to cause vibration or axial movement of the moving part. Fan replacement is the most effective solution, and if you are not a good diy-er send it to a laptop repair shop. You may some tips in the Thinkpads forum where some chaps tinkered with their noisy fans.
Mar 14, 2014 | Lenovo Ibm L3000 G400 15.4" Laptop Lcd...
The fan is making an annoying noise
Usually, this occurs when the fan has accumulated dust. You should clean the area with a blower where is the cpu fan. If the noise persists, you must have replace your CPU fan latpop.
Regards!
Feb 21, 2013 | Acer 15.6-inch Aspire 5735-4774 Laptop LCD...
HP laserJet 5200dtn making buzzing/humming noise
I suspect you have a noisy cooling fan. Nothing that will stop the printer from functioning but annoying I'm sure. You will have to have that fan replaced to get rid of the noise.
Aug 28, 2012 | HP Laser Jet 5200TN Printer
The fan is making a loud noise. It still works but wondered what can be done to stop the noise. It gets to be annoying after awhile.
Someone need first open and determine which fan is making the sound if it is a fan.
Some it may be normal but if a lot of dirt/dust gets on the fan's blades this can be the trouble.
If pinpointed to a single fan--replace it to find out.
You can also (a good resource) GOOGLE the model number with "fan noise" to see if known issue.
Mar 29, 2012 | Sony KDS-50A2000 50" HDTV
M400 after start gives annoying vibration noise (sounds like from the fan, but might be any rotating part) Screen is working ok
hi,
There are two possibilities.
1. The lamp cooling fan faulty
2. Bearing of color wheel get damaged.
Any one of these to can make such vibration noise. Check both things.
ok
Feb 14, 2011 | IBM M400 Multimedia Projector
My laptop makes a very strange noise all the time when I turn it on it is a extremely annoying occurrence. I have had this problem for a long time it doesn't affect the way it runs it just is annoying.
Possibly the CPU cooling fan. I would strongly reccomend you get this checked soon, a CPU cooling fan is relatively inexpensive to replace compared to over-heated laptop components!
Jul 05, 2010 | Computers & Internet
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Mold in the rinse aid compartment.
You should check your pump located in the back of the machine to make sure that it is pumping water out. Also see why the fan is making noise and replace the fan. Also check your hot water supply. Mold wont grow if the water is the temperature it is supposed to be and seems like youa re just washing with warm water or even cold
Feb 16, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
