Question about LG WM-2277HW Front Load Washer
Lg washing machine eror code 03? - LG WM-2277HW Front Load Washer
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Posted on Dec 15, 2009
pjhislay1
  • 822 Answers
SOURCE: i had an Frontloading LG washing machine model no WD-10481TP 7.5kg . its just keep overflowing at its max and it doesnt start the washing cycles the display signals : blinking only on AN E Code ?
read the error codes here ...
http://www.lg.com/ae/support/support-product/lg-WD-10481TP
cheers
Posted on Dec 04, 2016
I have lg front loading washing machine and it dislays DE , i know its means door error, but the door is closed , still the same eror. Can some one suggest.
Closed but does it lock closed so the washer can run . try leaning against the door .if it works call a repairman and get it replaced
Oct 24, 2015 | LG Washing Machines
The erore E33 little swan front loading w/ machine
I suggest that you search online for "error code e33 + little swan" you'll find most websites will offer some information.
Jul 11, 2015 | Washing Machines
What does code 03 mean on my lg washer wm227hw
Have you checked your LG Washing Machine Manual for a List of Error Codes?
Usually the code is generated by a switch or sensor.
There are several things like water level sense, door closed switches.
Obviously one of these is the cause..... I Know..... But which One!
Mar 03, 2015 | LG Washing Machines
What does fault code 03 mean?
The O code on an LG washer is a long drain code. It is saying that it has not drained within ten minutes.
You will need to check the door on the lower left hand side and clean out the filter. If the filter has nothing in it, you will need to replace the pump.
Oct 07, 2014 | LG Washing Machines
08 LG washer not draining and reads 03. What's the problem?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Nov 03, 2012 | Washing Machines
I have an lg direct drive 9kg washing machine and the water does not empty from the drum it flashes 03
03 error means drain pump is blocked or broken check the filter first before having someone out.
Jan 10, 2011 | LG Washing Machines
My washer wont drain and Im getting a 03 code appearing what does this mean
Jan 06, 2011 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
283 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
