Question about Toshiba Satellite A55-S106 Notebook
Boots up then shuts off and reboots then shuts down again, it just keeps this cycle up
    Genius:
  • 1,672 Answers
Check ur bios, put it in DEFAULT and exit....try it!
Posted on Nov 09, 2010
My E5430 laptop will not reboot - tries to and then shuts down
Can you boot into diagnostics without it shutting down? Try it while plugged in and the battery removed.
Jun 25, 2014 | Dell Latitude E5430
Continue reboot loo
There are a lot of possible reasons for this.
1. Fan is bad.
2. Motherboard has gone bad.
Do you still see the Compaq logo when you turn it on?
David
Jun 10, 2013 | Compaq Presario 700 470024-192 Notebook
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
Hp nx6110, stays in a boot-up loop
Hi, If you are sure that it's not overheating, then it could be the hard drive.
A boot up loop is an indication that the boot up sector on the hard drive is corrupt and broken. The hard drive tries to find this boot sector to boot up your computer but it can't. It keeps trying to find it again and again and again and keeps looping. Hank
Jul 23, 2010 | HP Compaq Motherboard
My Extenza 5420 won't complete updating and start up.
boot from the windows cd. select repair option. it will ask u" which windows u want to repair?". press 1. then in command prompt press the following commands.
c:/> fix MBR
c:/> fix BOOT
ignore the warnings u get in between when u enter the above commands
Sep 09, 2009 | Acer Extensa 5420-5687 Notebook
Virus...need to reboot
hi.. shut down ur system. re start again. hen ur computer restarts keep pressing F1 key. it will auotomatically guide u to the re boot process... the F1 key is also called as boot menu key..
pls rate me
Jan 21, 2009 | Averatec 1000 Notebook
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
Startup
You'll have to check if windows is loading before it restarts. If windows starts loading before it shuts down and just loops all over again, you can easily fix this by simply re-installing your operating system. you can do this by booting from the recovery discs that came with the laptop. Now if the rebooting cycle happens before windows starts loading then this could either be a RAM or a motherboard issue and will need to be serviced.
If you don't have a copy of the recovery discs, you can always call Toshiba at 1-800-457-7777 and purchase one from them.
Sep 07, 2008 | Toshiba 2405-S221 Notebook
Computers & Internet Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
