Question about Garmin GPS
Why when i plug the garmin nuvi into my computer it wont turn on?
  • Garmin Master
  • 587 Answers
You connect to your computer just for updates and if your unit takes music it will transfer that way too, it will not turn on to view map.....you may charge it this way also but to get a full charge it take maybe 3 hours...
Posted on Nov 09, 2010
My garmin nuvi 2495lm wont turn on at all
try leaving it plugged into wall power overnight to make sure it's not a low battery. Otherwise, if nothing changes when you plug it into the computer it sounds dead. Hope it is in warranty, otherwise I think Garmin will give you a trade in value towards a working unit or repair it at reduced cost. Call them at 1800-800-1020
Aug 03, 2014 | Garmin nuvi 2495LMT 4.3" GPS Navigator...
When i plug in my garmin gps it shows a picture of a computer and a wire plugged into it
MY GARMIN NUVI WONT SHOW MAPS AND CHARGE AT THE SAME TIME, WHAT SHOULD I DO
Mar 06, 2011 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 205 wont boot up
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then attempt a hard reset.
Finally, replace the firmware and system software using webupdate.
I hope that helps.
Apr 03, 2010 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 205w and now it wont turn on.
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
I hope that helps.
Dec 28, 2009 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 1300t wont get past the opening screen. my computer also will not recognizee it when i plug it in?
A Garmin Nuvi 1300 that won't start, freezes, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Sep 28, 2009 | Garmin nuvi 1300 Car GPS Receiver
Screen is stuck on "garmin nuvi" and the on/off wont turn it off, and the device wont boot up.
It sounds like you have your gps plugged into your computer with the usb cable and that what you are seeing on the gps screen indicates that the gps has communicated with the computer. This is exactly what should happen. However, you cannot use your nuvi as a gps in this mode and you cannot turn it off and on.
Jul 31, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Jun 01, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 360 wont unlock maps
Master reset is after you turn on the GPS put a finger on the left lower corner rightaway and then keep the finger there, wait until it shows up the "Do you really want to start up in maintainance mode"
You are not able to use others nuvi's map on your nuvi 360, as each map must match with the GPS unit ID, to find out your GPS's unit ID, go to "Setting" tab on "System", tab on " About"
Mar 29, 2009 | Garmin NUVI 360 GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
