Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Posted on May 23, 2017
Buzzer won't stop - whirlpool gold accubake system, single electric oven, ceramic hob, puh button electric start for oven controls, timer etc
This oven started making a terrible noise by itself at 7:30am, waking us up - in retrospect it possibly sounded like the self cleaner, but can't be sure as I have never used it. I unplugged it from the wall & plugged it in again some hours later (upon getting up) resulting in a constant buzzing from the control panel & no LED display, like the timer going off. The hob itself still works, but I can't turn the oven on as no buttons on the control panel as responding. The oven is not locked.
  • paasta Aug 03, 2008
    same problem sounding like a motor going on in the background.....happened last night. I took the front panel off after removing it from the circuit. No apparent damage or fault internal to the timer/ clock assembly. I have Whirlpool model RB170PXL.
5 Related Answers
Anonymous
  • 184 Answers
  • Posted on Apr 10, 2008
SOURCE: oven door locked and dead panel
TRY UNPLUGGIN THE RANGE FOR FIVE MINUTES AND THEN PLUGGING IT BACK IN. IF IT DOESN'T RESET AND UNLOCK, YOU COULD HAVE EITHER A BAD OVEN SENSOR OR BAD CONTROL(CLOCK). IF YOU ARE A DO IT YOURSELFER, YOU COULD BUY A NEW OVEN SENSOR, REMOVE THE BACK PANEL FROM THE RANGE(THE LARGER LOWER PANEL) FIND THE SMALL CONNECTOR PLUG THAT COMES THROUGH THE BACK WALL. IT HAS ONLY TWO WIRES ATTACHED TO IT. DISCONNECT THE OLD SENSOR AT THAT POINT AND CONNECT THE NEW SENSOR. IF THE OLD SENSOR IS BAD, THE DOOR WILL UNLOCK AND YOU CAN THEN REPLACE THE BAD SENSOR
THROUGH THE OVEN OPENING.
Frank Chen
  • 330 Answers
  • Posted on Jul 10, 2008
SOURCE: whirlpool gold accubake system stove/oven
Can you unplug the plug for a while? Are you the new owner ?
Do you have home owner insurance?
Henry Russ
  • 31 Answers
  • Posted on Feb 07, 2009
SOURCE: whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Anonymous
  • 41 Answers
  • Posted on Aug 28, 2009
SOURCE: Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
Anonymous
  • 725 Answers
  • Posted on Oct 22, 2009
SOURCE: I have a Whirlpool Self
When you use your self clean feature, your oven heats up to over 800 degrees and this normally takes your electronic computer control board out.
The model number and serial number on my Whirlpool gold electric stove have faded out on the sticker of my stove. Please help me in finding the model and serial number of the stove in the attached image.
I notice is it also in French, so I am guessing you are Canadian? Greetings from Mississauga! Its a guess... but..
YGY397LXUS Whirlpool Range Canada - Sale! Best Price ...
www.canadianappliance.ca > Ranges > Whirlpool
Whirlpool Gold YGY397LXUS Slide In Electric Range, 30in, 4.5 cu.ft, with AccuBake Temperature Management System, Self-Cleaning Oven, Delay Bake, ... This AccuBake system uses a sensor to monitor the oven temperature; it will then turn ...
Whirlpool GBD307PDS09 Built In Oven - Electric Timer - Stove ...
www.appliancetimers.ca > appliance
I have a Whirlpool Gold double oven and someone came to house and told me it ... black panel on whirlpool accubake system self cleaning oven gives double ...
Somewhere hidden in the stove, should be the engineers spec sheet. It should be one of these images
https://www.google.ca/search?q=%22whirlpool+gold%22+%22self+cleaning+oven%22+%22Accubake+system%22
Here is your error code
There may be a problem with the Oven Temperature Sensor, the Warming Drawer Sensor (if so equipped), or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) minute. ... Monitor the oven for one (1) minute to ensure the error code does not display again.
Dec 14, 2019
F3 E2 - Electric Range - Product Help ' Whirlpool
https://producthelp.whirlpool.com/Cooking/Wall_Ovens_and_Ranges/Electric_Ranges/Error_Codes/Error_Code%2C_Fault_Code_or_Message_-_Oven_Control/Starts_with_F3/F3_E2_-_Electric_Range#:~:text=There%20may%20be%20a%20problem,for%20one%20(1)%20minute.&text=Monitor%20the%20oven%20for%20one,code%20does%20not%20display%20again.
When oven circulating fan is on there is a virbration. how do you locati the fan?
Fan is located in rear of stove or maybe a piece if foil paper for into blades
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
I have an accubake electric oven. The lower heating element will not turn on. The timer and clock etc. work. It is a new appliance.
It sounds like the electronic timer/clock is in the automatic mode. It must be in the manual mode for the oven to work.
1helpful
Timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
2helpful
2answers
2helpful
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
1helpful
2answers
Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
10helpful
Whirlpool Gold Accubake oven
depress the broil button for 5 seconds it will revert back to Farenheit
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
