HP LaserJet CP1515n Printer Logo
Posted on Nov 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Double side printing - HP LaserJet CP1515n Printer
thane ntozini
Level 2:
New Friend:
  • Expert 121 Answers
  • Posted on Nov 09, 2010
thane ntozini
Expert
Level 2:
New Friend:
Answers
121
Questions
Helped
17597
Points
374
To printer on either side you need the duplex unit, sometimes you find it not installed
Double sided printing
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
2answers
How can I do double-sided printing with my Canon MP460?
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
2answers
How do i print double sided?
No unless your printer has an add-on or built-in mechanism that allows for double sided printing,
How to print double sided?
Most hp deskjet printers are not enabled for double-sided printing. This feature is common with laserjet printers. So if you are using a deskjet, please you may to manually print your double sided.
If your printer is a laser jet you will find the selection under your print menu. Press ctrl P (keyboard) and the print menu appears. Click on each tab to see which one is contains the double-sided selection button. select it and print. The tab should be titled "Basic" depending on the your printer.
If your printer is a deskjet, go through this procedure to see if your model is enabled for double-sided printing and enable it.
Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Printing everything double sided
go in youre ip address, log in as admin, chooce print tab and there is a print tab, there is a default options, and choose double printing off
1helpful
Can the 420CN print double sided pages
There is only a manual double sided printing avaiable:
After the first side was printed you have to turn the page into the papertray again.
Canon bubble jet printers can do double side printing but the back side black print will be mingled through C/Y/M ink!
k24674
Grand Canyon Tech
Grand Canyon Tech
