Question about Husqvarna Garden
I have a 1994 husqvarna LT140 with a briggs and stratton 14hp motor, i pulled it down to replace a bottom end gasket, and i have one single red wire, that i cant remember nor find where it goes, can anyone help?
    Master:
  • 680 Answers
How to wire up my 13.5hp coil & charging system
Only need a simple double pole, single throw toggle switch. One side to power (battery) other to solid ground, to run power to starter motor Starter motor may have a ground on it also. See u-tube video, starting a riding mower.
Feb 12, 2017 | Briggs & Stratton Garden
Murray lawn mower model number m20300 trying to locate carberator
Murray M20300 is produce by Husqvarna (HOP) group. Its product number should be 96114002702. It uses a Briggs and Stratton engine model number 9T602-5019-B1.
The carburetor PN is 795475 which include the 795083 diaphragm and gasket. This diaphragm and gasket is most problem found when the carburetor fails to operate. Considering the cost of the carburetor kit it is just cost effective to purchase the whole carburetor replacement kit.
You can purchase from online vendors that sells Briggs and Stratton parts or purchase local from a local shop that deals with Briggs and Stratton engines.
Mar 26, 2015 | Murray Garden
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Riding mower with 26hp briggs and stratton motor runs about 20 to 30 minutes thens cuts out
It sounds electrical in nature check the solenoid for continuity, check your key switch it may be bad also, check the spark plug wires and the part they hook into. Look for melted wires and replace as needed.
May 11, 2012 | Husqvarna Garden
The govenor rod cannot be adjusted. The springs are intact. Motor revs up but will not idle down. It is 23 HP.
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton wiring, can it handle an electric clutch?
You might have a capacitor in line with the clutch motor that requires feed from the engine to allow the clutch to engage. I think the red lead is charging current to the battery plus post. Get yourself a 270962 repair manual and it will show you how to wire these things.
Apr 13, 2010 | Garden
Riding mower backfired; now leaking gas.
Carb gasket will most likely need to be replaced. Good idea to pull apart, clean and soak carb and floats anyways in the process.
Nov 08, 2009 | Garden
14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Aug 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Red end cap on new motor!
pull the cap off and look there,it is probably covering an adjustment screw for carb.
Mar 27, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
200 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
