Question about Hotpoint WMM53 Front Load Washer
My washer wont spin keeps saying f5 all the time and wont open to get washing out
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
SOURCE: kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Posted on Oct 15, 2008
SOURCE: My front loading ge washer will not finish washing
I had to call a repairman for the same problem. Your pump is clogged with lint and debris so the water will not drain or slowly drains. There is a sensor that will stop the cycle if the water is not draining. Open the bottom panel at the front of the machine. (there are 2 or 3 screws) Then on the center right there is circle thing (about 2 inches in diameter) ** Important** place a small flat pan, etc underneath the opening and unscrew the cover. Water and other misc. junk will come out. Reassemble everything and you are set. Why they don't provide this information in the manual I do not know. Easy repair for a common problem.
Posted on Jun 09, 2009
SOURCE: Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Posted on Jan 09, 2010
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
How to restart the cabrio washer
my washer when spins knocks like crazy from the inside when spinning and sometimes when on the wash cycle washer keeps saying unlevel but clothes are level
Aug 14, 2012 | Washing Machines
Keeps coming up with f5 wont pump out or spin
You need to chjeck and clean the pump filter.
Remove rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Nov 29, 2010 | Hotpoint Aquarius WD640 Front Load...
Jun 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer spin and not enough water
Spinning both ways is pretty normal. You did not say if your clothes were clean in the end. You may not see much water when it washes, when it rinses you may see about 1/3 thru the glass. Careful with the door aft wash, wait for 2 minutes before opening.
Feb 28, 2009 | Washing Machines
Cannot open door
f5 means a blockage. you will need to drain it by putting the drain hose lower than the machine to syphon it out into a basin. then you can check the filter for the cause.
Jan 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Front load washer wont spin
it must drain before it will spin.if water is standing in it .remove power take off frount panel.remove screws that keep pump onthe washer move towards bucket and open pump and clean out.God bless tom
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore oasis washer
top loaders use the same motor for wash pump and spin to spin the clothes the motor direction is reversed and a solenoid releases the drum brake allowing the drum to rotate this is governed by a set of clutch shoes in the pulley if these are worn then the machine wont spin at full speed but ol on the display indicates overload so check the solenoid is releasing the drum usually heard as a loud clunk on spin start
Apr 01, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
My machine won't spin, they say try the belt but Where's the belt?
THERE IS NO BELT ... IT IS USUALLY THE LOADING DOOR SAFETY SWITCH THAT SHUTS OFF WASHER WHEN DOOR IS OPENED DURING SPIN CYCLE. THAT SWITCH CAN GO BAD. THIS IS NOT AN EXPENSIVE REPAIR ...
Apr 28, 2007 | Crosley CW6000 Front Load Washer
Hotpoint WMM53 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
