Question about Kettler TX1 Treadmill with FREE INSIDE Delivery! Treadmill
The machine toronto cardio fitness shows SIL and machines restarts when the weight of persons goes beyond 65 kg.
Model 27. How much does it weigh?
A model 27/127 coincidentally weighs 27 pounds (12 kg), plus the weight of its motor, treadle, or hand crank, its light, and its case or cabinet. Such a weight strains the meaning of the term 'portable', even when fitted with only a hand crank and minimal wood case. Singer Model 27 and 127
Mar 21, 2016 | Singer Sewing Machines
Are fitness routines different for women than men?
Fitness boxing for women varies slightly in style. Boxing fitness for women is tailored specifically for women focuses more heavily on whole-body fitness with a stronger emphasis on thighs, legs, **** and back. Male fitness boxing, alternatively, is geared more toward an upper body workout.
Aug 07, 2012 | Boxing
Could I "stack" a front
i would not recommend stacking one machine directly on top of another. there are various issues with weight, and movement due to vibration.
what you can do is built a solid "workbench" that you can fit one machine under, and then put the other machine on top of the "bench"
personally i would overbuild the bench, using 2" by 1" wood for the frame, braced and bolted to the wall for stability, and use a 1"thick worktop forv the top of the unit. on the top surface, i would also put a 3/8" wooden beading strip about 1/2" fron the outside edges of the worktop to stop the machine moving with vibration and falling off.
i have done this a number of times when space is limited, although i find it much easier to put tehr dryer on the top as it is the lightest of the 2 units.
hope this helps
Apr 01, 2011 | Washing Machines
To whom it may concern hello I have bosch washing machine was32794 , 1-can I use bleach?may be it damage the machine? 2-how can I distinguish the weight of cloths is more than the capacity of machine?...
Yes, you can use bleach -- about 1/2 cup oer load -- or more if specified in owner's manual.
The machine could handle easily one full laundry basket -- see below.
  • Capacity of typical Laundry Basket = 6 kg (dry weight)
Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
Charlie
Feb 23, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Machines are used to pack sugar into packets supposedly containing 1.20 kg each. On testing a large number of packets over a long period of time, it was found that the mean weight of the packets was 1.24...
Machines are used to pack sugar into packets supposedly containing 1.20 kg each. On testing a large number of packets over a long period of time, it was found that the mean weight of the packets was 1.24 kg and the standard deviation was 0.04 Kg. A particular machine is selected to check the total weight of each of the 25 packets filled consecutively by the machine. Calculate the limits within which the weight of the packets should lie assuming that the machine is not been classified as faulty.
Nov 11, 2010 | Refrigerators
How accurate are the calorie counters on treadmills and cardio equipment?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Kettler TX1 Treadmill  with FREE INSIDE Delivery! Treadmill Logo
176 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
