Question about Dishwashers
Currys essential slimline dishwasher will not drain
3 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: Hi, I have a currys
Hello & Welcome to FixYa
First clean the drain filter pump assembly located inside the front bottom access panel. If the problem is still there after cleaning the drain filter assembly then it means the control board is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 14, 2011
caroldon
  • 17130 Answers
SOURCE: I have a Currys CDW45W10
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Posted on Aug 22, 2011
I need user instructions for currys essentials CDW45W16 slimline dishwasher. Please can you help?
Partmaster.co.uk has the Curry's essentials CDW45W16 dishwasher manual. The direct link to the manual is https://www.partmaster.co.uk/images/mediator/1513/currys%20essentials%20cdw45w13.pdf . I found this through a Google search for CDW45W16 manual.
I hope this helps.
Dec 09, 2016 | Dishwashers
Do you have a user manual for a Stoves slimline integrated dishwasher model number s450dw?
Contact Curry's or Stoves direct
http://www.currys.co.uk/gbuk/household-appliances/dishwashing/dishwashers/stoves-s450dw-slimline-integrated-dishwasher-19091081-pdt.html
Understanding how it works will help you get the most out of your Stoves product. Search by model number or scroll down to find an instruction manual.
If you dont find the manual your are looking for call our product helpline on
0844 815 3746
Manuals
May 26, 2016 | Stoves Dishwashers
Currys Essential Slimline CDW45W10. Why is water not getting hot?
These seem like the siemens/bosch type. There is a heater relay that can go bad. Its in the front panel. Check the relays in the front panel for bad solder or burn marks.
Sep 02, 2015 | Dishwashers
Instructions to get access to the drain pump for currys essentials cdw60w10
The best bet is to go on line to the manufactures web site and ask customer services to let you download the schematic and manual, free of charge. You need this schematic to follow the procedures when disassembling and reassembling the parts.
Mar 16, 2014 | Dishwashers
Currys essentials dishwasher error warning
Just installed a CDW60W16 at my daughters house. worked ok empty but as soon as it was loaded the glass icon lit up and beebs. when I turned it over to take a look at the float switch I noticed that the levelling legs were all screwed in so the base of the machine was sitting on the floor. so when the machine was loaded the pressure switch operated as it was being pushed up by the floor. I unscrewed the legs a few turns to allow an air gap between the floor and base of the machine and all working fine now. on checking the installation instructions it only mentions loosening the legs to level it if required which is wasn't. maybe the manual should give instructions to unscrew the legs a few turns to prevent this
Aug 24, 2012 | Dishwashers
My currys essentials cdwtt10 dishwasher is showing an error code E3?
https://www.google.com/url?q=https://webcache.googleusercontent.com/search%3Fq%3Dcache:OPXBPu7tuokJ:http://www.buyspares.co.uk/images/mediator/1513/1)%252520instruction%252520manual%252520cdwtt10_ib_final100413.pdf%252Bcdwtt10%26gbv%3D1%26hl%3Den%26ct%3Dclnk&sa=U&ei=LyZwUZH_JOOM0AXIsIDoCg&ved=0CC4QIDAEODw&sig2=6sN7aESIiy5pjbjk2Hk34g&usg=AFQjCNH_UPwOjOW7e2lIRMSJj2ik3P7Ukg
Feb 25, 2012 | Dishwashers
Dishwashers Logo
1,273 people viewed this question
Top Dishwashers Experts
