Question about HP LaserJet 3055 All-In-One Printer
Just "add paper"
  • 121 Answers
Use a blower to clean the inside of the printer, most likely you got a stuck or failing sensor
Posted on Nov 09, 2010
Our Panasonic WORKiO 1520 copier is giving us the error message
try and place the paper back on the tray properly for the censor to pick it i encounter this problem everyday but i just reset the paper.
Oct 12, 2012 | Panasonic WORKiO DP-1520P All-In-One Laser...
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Hello, I have a HP Color Laserjet 5550DN that works great. Except when I try to print out some photo's on a regular piece of paper. It says "not enough memory". The photo's are about 4MB...
It has 4 memory slots. If you can add what you need to get 512 meg, that should fix your problem.
You say that "some photo's on a regular piece of paper." , get the error, but if you use photo paper it prints ok. Doesn't make sense. Add the memory.
Jun 27, 2011 | Office Equipment & Supplies
Kyocera Printer is not printing. Error is "Add Paper. Letter"
This is a common error due to many printers set default paper printing size as a letter size, and you don't have it in printer.
You need to set the output paper to the one that you have (I guess it is an A4) in advanced setting on the printer.
Hope this help!
May 20, 2011 | Office Equipment & Supplies
I have a P915 printer that even though there is paper loaded and no paper jam the paper won't feed. It will start to run and the message "add paper" appears. It appears the "feeder...
There could be some sort of foreign objects that fell into the paper feed system. Remove the sheets of paper from the printer. Grab a flashlight and look into the feeder for any debris. If you are capable and willing, you may carefully turn the printer upside down so any foreign objects will just freely roll out from the feeder.
Re-seating your cartridges may also help resolve the problem. Remove and properly reinsert your cartridges in the cartridge carrier. Turn off/on your printer to reset it.
Apr 15, 2011 | Lexmark P915 InkJet Photo Printer
My Xerox Workcentre PE120i screen says [no paper] "Add paper". but the tray is full of paper. What do you suggest I do?
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Dec 20, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
"Toner not set" persists, even though new
Hey!This happens a lot!Take out all of the paper,Open the cover,take out toner,put it back and add paper!!If this does not work then the toner sensor might be faulty!Good Luck!!
Nov 03, 2010 | Canon imageCLASS® MF4150 All-In-One Laser...
My printer says "no paper",
try adding paper to any handfeed trays that the printer may have. check the print que to see if that gives you any information
Oct 28, 2010 | Dell Office Equipment & Supplies
HP LaserJet 3055 All-In-One Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
