Question about Canon PIXMA iP1800 InkJet Photo Printer
My Canon ip 2772 Printer does not works. It says Error 6000. What Can i do? there is no paper jam in my printer. Plz Help
  • hassan_raja1 Apr 19, 2011
    canon ip does not work
  • elsa_gemina
    elsa_gemina Sep 22, 2012
    how to fix error 6000 for canon ip2772
My Canon ip 2772 Printer does not works. It says Error 5200. What Can i do?
Posted on Mar 02, 2011
My Canon ip 2772 Printer does not works. It says Error 5200. What Can i do? there is no paper jam in my printer. Plz Help
Posted on Feb 27, 2011
Eror 6000
Posted on Dec 08, 2010
  • Kurtis not found
Posted on Dec 14, 2010
What is service code 6000?
Hello Richard Miller
The error that you have, it means that your printer has a paper jam, this is the error appears in you computer, may be in the printer have the next error number. P3 followed E3
If you are writing this review, it is because they believe you have a paper jam, if they have seen and removed yourself.
Principally printers and Canon, in many cases the system detects a paper jam, but is not exactly a paper is causing the problem, in many cases can be any object that has entered and is obstructing the passage of the pages.
My first recommendation is to look carefully where they enter the pages on your printer, if necessary use some lighting for better viewing, you might find something there.
If after all get nothing related, follow the steps below to solve your problem. http://www.en.rellenadodecartuchos.com/2015/04/delete-service-error-6000-or-p3-fallowed-e3-canon-pixma-mp240-printer.html
Even then, you can not solve the problem, I recommend the following way, which is to eliminate jam Canon inbox.
service-code-6000-xnnjabddbe1z3hwtjta3ekn0-4-2.jpg Remove error 6000 printer Canon PIXMA MG2410 en Rellenado
To be honest most of the time are other elements that influence paper jams, which can not be determined on the Canon printers.
Nov 20, 2015 | Canon PIXMA Office Equipment & Supplies
Try these:
Solution 1:
  • Verify that the paper tray is correctly set.
  • If any object is placed in front of the machine, remove it.
Solution 2:
  • Search for any small pieces of paper in the printer, or a tiny object.
Solution 3:
  • Power off the printer
  • Wait 5 minute
  • Power on.
Solution 4:
  • Clean the encoder strip with a soft cloth
Solution 4a:
Jun 01, 2015 | Canon Pg40 Ink Cartridge for Fax Jx200,...
Service error 6000 for canon pixma iP 1600
Error 6000
An error occurred in the LF encoder signal.
Can be the result of a deep paper jam with pins, paper or other miscellaneous objects stuck in there.
Check the unit and clean thoroughly.
Jan 15, 2013 | Canon PIXMA iP1600 Printer
How could error code 6000 in ip2772 can be fix?
there is a problem in the gear during initialization of the printer, maybe there's a tiny piece of paper that cause the gear wont move, the best solution is to open the printer to see if there is a foreign object inside in it.. that's all
Jul 03, 2012 | Canon Pixma iP2700 InkJet Photo Printer
Problem with canon ip 2700 .....the printer show error 6000 :s wtf i can doing ? :)
Canon IP2700 6000 Error
Error 6000 tells you that the paper feed roller is not turning, check for any foreign objects in the paper path, a flashlight and small mirror is the best way to look.
yes.. i agree on this statement..
just try this one., its tested by my own experience., first turn off the power of IP2700 printer
then just try to turn the gear of paper feed roller in order to release
the foreign objects..
if error persist, just try to turn the gear again until it works ok.
pls send feedback if its work., salamat., mabuhay pinoy.
Mar 24, 2011 | Canon Pixma iP2700 InkJet Photo Printer
E-703 error code coming what is this
Mar 02, 2011 | Sharp AR-M162 All-In-One Laser Printer
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
1,984 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
