Question about Mag Innovision InnoVision 996PF (White) 19 in.CRT Conventional Monitor
Have a Mag 996pf and want it to run in Windows7. I can find drivers for the older OS (at driversguide.com) but there's no way I can get them to run in compatiblility mode (xp2) for Windows 7. I need the proper drivers so that I can change the refresh rate.
Your Computers hardware is Mag 996pf. You like Windows7 to be the software. An installer is what you like.
Posted on Nov 14, 2013
2 Suggested Answers
  • 68 Answers
SOURCE: monitor display shifted offscreen
I would be carefull with refresh rates unless you know the maximum and minum rates to apply to your monitor. I solved this problem before for someone and what i recomen is to set your normal desktop to the same resulution as your computer games. That way when you leave your games or reboot it will be the same. See what is happening is when you play your games it is a higher resultion then your normal desktop. And when you log off from it your monitor has to re adjust to the old settings. This will cause a shift. By setting them both the same you will avoid this problem all together.
Posted on Sep 20, 2007
[MSI MS -7104] VIA P4M800 Can windows7 run on this motherboard??? Plz reply and help
As long as you have enough memory installed (at least 1 GByte, but better is 4 Gbyte) it should be able to run windows7 Most of the time it is more difficult to put an older operating system on a mother board, because the older OS'n don't support newer drivers.
You could check with Microsoft to make sure they support this board, with the newer drivers.
Jun 14, 2014 | Computers & Internet
My web cam wont work
If you have recently upgraded to windows7,there is a probability that some of your peripheral devices will not work on this opreating system(OS).Several users are found that their webcam, which worked perfectly in older version of windows,is not recognized or does not work correctly under windows7-(they get error which says their webcam is not compatible with this os or experience message like"device cannot start"etc)
you may think there is no other option other than to run out an purchase a new webcam-however before you jump the gun,lets look some troble shooting steps that can get working your webcam working correctly in windows7
TROUBLESHOTING Step 1:Install webcam driver
This step needs to be followed if your webcam is listed in device manager and you can see a yellow
exclamation mark next to it.(see image below)
Note: The yellow exclamation mark usally signi files that there are no compatible installed for device
Driver are small soft ware programs that enable the os to recognize and control the devices attached your system.you can other use a tool like DRIVER FINDER to easly scan and download your missing webcam device drivers
PLEASE VOTE ME AND RATE IT
Sep 05, 2011 | Acer Aspire 5610-4648 Notebook
I have the dvdxcopy program and I can't activate it. It won't take the license and password inside the box. This is a very good program but it is older. how do I activate it? license 2010086 password...
1. Your program may be to old for the OS (operating system) that you are using
2. You will need to run the compatibility utility ( if you are using Windows XP or Windows 7
3. Here is the instruction set to run older programs in Windows XP
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/appcompat.mspx
Here is the instruction set to run older programs in Windows 7
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 07, 2010 | 321studios 321 Studios DVD X Copy (Backup,...
Iam using SAA 713X T.V CARD for xp .now my p.c os changed to windows7 but t.v card not working.how can i fix this problam can u help?
You just upgrade to new Operating System i.e. Windows 7. So all devices like Tv tuners cards etc. have different drivers for all operating systems . So you have to install the drivers of your Tv tuner card which is compatible to windows 7. Go to www.driversguide.com or go to your Tv tuner card maufacture site for drivers.
Aug 15, 2010 | Computers & Internet
I need driver canon powershoot a430 for windows7
windows 7 is a new os hence all the drivers are not available yet. so install the vista driver in the older version compatibility mode which can be done by opening control panel of your computer then go for the options of progams and features and then install the older version program. then it will work
Jan 18, 2010 | Canon PowerShot A430 Digital Camera
I installed windows7 and now my cam is not working
its because (junky) win/7 doesnt support drivers for most cams ect that was made proir to win/7 it's the GAME! write new o/s and sell new hardware manufactuers been doing it for years its there way to get you to buy new products!
go to www.driversguide.com if there is a win7 driver available they will have it! good luck
Jan 14, 2010 | Genius VideoCAM Messenger Webcam
I cannot install my Genius colorpage-hr6x slim scanner in windows 7 64 bit OS
Thank you for Posting in Microsoft Community.
I understand that you are unable to connect the scanner to Windows 7 computer.
I can imagine the inconvenience you have experienced. I will definitely help you with this.
Please install the scanner drivers in compatibility mode in Windows 7 and check if it works.
Refer to the link.
Make older programs run in this version of Windows
http://windows.microsoft.com/en-IN/windows7/Make-older-programs-run-in-this-version-of-Windows
I would also suggest you to contact the scanner manufacturer to check for the availability of Windows 7 drivers for the scanner.
Oct 24, 2009 | Office Equipment & Supplies
Mag monitor signal cable faulty
look into the 15 pin vga connecter care fully you will look numbers 1 to 15 which is very small it configration is as follows
1)red
2)green
3)blue
4)gnd
5)gnd
6)r return
7)g return
8)b return
9)5v from vga card
10)stand by
11)sync gnd
12)Sda(serial data)
13)Hsync
14)Vsync
15)Scl(serial clock)
at another end same letters will see take continuty and join new cable
Nov 10, 2008 | Mag Innovision InnoVision 996PF (White) 19...
Mag Innovision InnoVision 996PF (White) 19 in.CRT Conventional Monitor Logo
109 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
