Question about Belkin Basic Wireless Router
Can't play other players online with PS3 because of NAT3 network configuration.
  • 38 Answers
There are many reason as to why NAT3 is not open. First is the ISP's modem, verify from your ISP is set into full bridged mode. If it is just half-bridge, informed your ISP to help you set modem into full bridge mode. Second is forward the port numbers TCP: 80, 443, 5223 and UDP: 3478, 3479 in your router. You will access the set-up page of your D-link router and click "advanced tab" and choose "port forwarding"
Posted on Nov 09, 2010
Can I play playstation 3 online with a E1000 cisco router?
You should be able to connect to the Internet provided the PS3 wireless segttings is configured correctly.
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Aug 11, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I just bought my first ps3 in order to play some friends in madden online. I have everything connected and can go on the internet and watch netflix, the only things i can not do is access the playstation...
First make sure that your PS3 connects with your acces point eather wireless or with wire, te second step is configurate your PS3 for wire connection or wireless connection.
These settings are found under the network settings.
Also see the manual to see how you need to configurate the PS3 in detail.
Allso make sure when the PS3 is connected corectly to the acces point that the firewall of the acces point is not interfearing the connection.
May 21, 2011 | Sony Playstation 3 (PS3) Console
Can connect to internet, but not playstation network to play call of duty online. no problem with streaming netflix. just get error code when needing to sign into the playstation network.
That is most probably result of server host not working anymore, check Call of duty (for example 4, black ops....etc) _____(Platform, PS2,PS3,XBox,...) online status. If they are not working, for that time you wont be able to play it. As far as you have explained you have configured your console online, so its not problem with you :) Good luck my friend! :)) Thx for asking me.
And please rate my solution! :) Thx in advance .Alex
Apr 17, 2011 | Video Game Consoles & Games
Says i have nat3 network setting connect problem for players
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
Why when i connect to the network to play it tells me ther is a dns error? i could go on the internet for anything else except to play on line >
You can assign a DNS server. It means that something is wrong with your DNS configuration.
You can use OpenDNS:
208.67.220.220 208.67.222.222
Set this up under the Network settings, manual configuration.
Jun 13, 2010 | Sony Playstation 3 (PS3) Console
How to hook ps3 up to the internet
Go to settings on the main menu and select network settings.can automatically and follow the prompt on screen. If your network has a security make sure to enter the security key and save the settings afterwards. Once configured, you'll be able to connect online and play with other players, access playstation store and browse the internet. hope this helps. :)
May 10, 2010 | Sony Playstation 3 (PS3) Console
When playing a game connected to the internet the game will play for a few minutes and then goes completely black
1)is your ps3 overheating?
2) is anyone else using the network your conected to?
3) are all your network cables conected and un-frayed,cut,pinched
4)dose your router go into a colisian state when you get the black screen?
5) dose it only happen in this online game or all online games
6)dose it happen every time you play this game or only some times?
6)are you trying to hack the game?
what port forwarding do you have configured for the conection to your ps3?
if none learn how to configure it to limit redundant broadcast that may be causing this problem.
try turning unplugging all systems from your router except the ps3
if you are conected directly to a broadband conection you might want to get a router so you can filter the trafic that reaches your ps3
hackers/cheaters are malicious and will stop at nothing to get the thrill of winning ,first learn how to do it ,then you can know how to stop it from being done to you ,or at least level the playing field at the cost of self respect
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Connection lasts about 5 minutes
Basically if you do a connection test on the ps3 and it comes back as NAT3 then you will have problems. You need to forward some of the ports of your modem to get to NAT2. You will need to assign static ip addresses to your PS3s so that you can set up port forwarding
You may have interference from a nearby cordless phone (keep these away from router), could be interference from neighbor, try changing channel you use on wireless router.
Some people have reported success just by turning off SSID broadcast in the wireless router.
PLAYSTATION®Network Guide
Jan 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi...unable to connect to ps3 using siemans gigaset se587 wireless router
hi there,
first you need to make sure u can access your wireless router with no problems and the wireless is turned on for your ps-3...then u need to forward some ports...
Turn on PS3 and goto Settings, Network Settings.
Select Internet Connections. If it asks you want to be disconnected select Yes. Select EASY. Select wireless
Select SCAN this will take a few minutes. The PS3 should find your router and already have the SSID# so just type in your WEP key. Select save and then wait a couple of minutes then select test. It should hook up.
If it hooks up with NAT3 then you will have to enable UPnP on you router. type in http://192.168.1.1 on your computers web browser.
username: admin
password: admin
Click on the advanced tab and then on Universal plug n play and then make sure both check boxes are marked.
Then on the PS3 make sure the UPnP is enabled also in the network settings.
This should give you network and NAT2.
please try this link for port forwarding help:-
http://www.portforward.com/english/routers/port_forwarding/Siemens/GigasetSE587/PS3_NAT_Type_3_to_2.htm
Apr 20, 2008 | Computers & Internet
Playing on line
The way this was resolved for me (and I know someone else mentioned it in an other post here), was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. Voila... I am upgrading my PS3 software as I write this.... ..btw, this also fixed the similar problem I had with my PSP..
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Belkin Basic Wireless Router Logo
178 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
