Question about Dell Dimension 3100 PC Desktop
I have dell dimesion 3100c when i turn it on the power on the cpu turns green , stayed amber/orange solid not blinking on the monitor and the pc wont boot. the monitor does not show anything but diagnotics light on the front of the pc are all green
  • 1,179 Answers
The green light on your computer is just there to show you that your computer is on. It is receiving power. Your computer is not POSTing often described as a no POST. Power On Self Test. One beep from the onboard speaker represent all is in good working order. However if you hear no beeps then some-thing is wrong, like in your case. Start by removing the side panel of your case. Remove the BIOS/CMOS battery for about one minute and the reinstall it in the correct orientation. This will load default settings. Now power on your computer. Does it work! If no then ensure that the fingers of the RAM modules are clean, use tissue paper and ensure that they are correctly installed. Remove the graphics card and reinstall it applying even pressure throughout the card and gently push it into the slot. There may be a little clip ensure it locks into place. If you can it is recommended to use the onboard VGA for your testing. Limit the number of variables by disconnecting all hard drives and DVD drives. Install RAM modules one at a time in alternate slots. Clean the computer of any dust, pay special attention to the CPU cooler as this must be kept cool at all times.
Let me know if this works for you, I am here to help.
damnor01
Posted on Nov 09, 2010
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Blinking amber light on the on/off button.
No light : The computer is turned off (S4, S5, or mechanical OFF)
Steady green :The computer is in a normal operating state
Blinking green : The computer is in a power-saving state (S1 or S3)
Blinking or solid amber See "Power Problems"
check power
Sep 06, 2011 | Dell Dimension 4300 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
When i turn the computer on the power button turns yellow but it don't turn green
1.Blinking or solid amber - "Power Problems"
2. If the power light is steady amber - The computer is receiving
electrical power, but an internal power problem might exist.
3. Ensure that the microprocessor power cable is securely connected to the
system board.
4.If the problem persists, contact Dell.
Dec 28, 2010 | Dell Computers & Internet
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
My pc is not turning on (all the light does is blink orange)
Woops -the blinking amber light of doom is a common fault on dells -
usually a solid amber is the Power supply while a blinking one indicates Motherboard problems. If machine is still under warranty dell will replace it.
If not then it will cost you to have them replaced.
Dec 07, 2008 | Dell Dimension E520 PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 3100 PC Desktop Logo
308 people viewed this question
Alun Cox
