Question about Xerox WorkCentre M20i All-In-One Laser Printer
"error stack underflow"
'error stack underflow' printing out when printing some jobs
any help?
  • 81 Answers
This is a problem with the document file. Microsoft has an article about it on their website. The link is
http://support.microsoft.com/kb/823135
Posted on Jul 24, 2008
I get a timeout message at the end of a print run
Toggle through the menus on the printer to the "Sys Config Menu" and turn OFF both the "Manual Timeout" and "Timeout in Job".
As a note, we only have this issue crop up when our printer is accessed through an Apple Time Capsule. When it was directly attached to the computer, or accessed directly through IPP we had never had the error page print.
Jun 03, 2012 | Oki Electric Industry B431dn Printer
Please help. The device prints once and then stops printing until restarted. This process continues between every print job. The message printed out from the printer is as follows: ERROR:...
This is a corrupted Postscript error.
Possible solutions are, reload up to date driver and/or firmware. Go to Xerox website address below for drivers and firmware.
http://www.support.xerox.com/support/phaser-4500/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB
This could also be a program specific problem, try printing from another software package.
Finally, you could try an NVRAM reset. Go to 'Troubleshooting', 'Service Tools', 'Reset NVRAM'. WARNING, before performing an NVRAM reset, print out a configuration page. 'Information', 'Information Pages', 'Configuration Page'. This print out will give you all the printers settings, including your network settings, which will be lost through the reset. You will need to re input them through 'Printer Setup', 'Connection Setup', 'TCPIP'.
Hope this helps.
Jan 21, 2011 | Xerox Phaser 4500 Printer
A document was sent to the 5110cn color printer. it is a full color duakl sided brochure. Keeps trying to print but errors out before loading all images so all that gets printed is one or two of the...
The reaason it keeps trying to print is because it's in the print queue on your network.
Have whoever sent this to the printer open the print queue and delete it.
Only the originator or the print queue admin can delete the job
Jan 06, 2011 | Dell 5110cn Laser Printer
Prints out: printing error: undefined offending command: stack It does this every time a job prints and is wasting a ton of paper. How do I stop this?
This is a problem with either your Formatter or your Network card (if seperate). The printer is no longer able to convert the commands coming into it. If your Network port is part of the printer and not a seperate card, you'll need to change the Formatter.
Apr 12, 2010 | HP LaserJet 8500 Color Printer
Error 49 4CO2 Service Error on a HP Laser Jet Printer 5500 DTN
This is related to the JetDirect Card and the specific print job attempting to print. If JetDirect is 615 or lower slide out JetDirect card and power cycle printer once it comes up o.k power down and
slide JetDirect card back in once the printer is back up look on the display for processing job which may take 5 minutes but it is the offending job trying to print again as it is still in the print que. If you are quick enough you can hit cancel on the display panel to cancel the corrupt printjob and if you are successful then the other print jobs stacked behind it should start printing away with no problem. Hp blames the 49 error on a plethora of problems though mine are usually related to documents using different versions of Adobe and also PowerPoint printjobs that are excessively large as the print spooler cannot handle them but it is always a corrupt print job and once that is cleared no problem. Occasionaly replacing the JetDirect card is required to solve the issue. With the 620 Jetdirect card no need to remove it just unplug the network cable same procedure as above.
Oct 22, 2009 | HP LaserJet 5500dtn Color Printer
How do I turn on my RAM disk? (Dell 3100cn)
the print job may be too large for the available printer memory.
Your choices are one of the following:
Press to clear the message, cancel the current print job, and conduct the next print job, if any.
· Press Cancel to cancel the current print job.
· Press Menu to open the Stored Print and delete the current job.
To avoid this error in the future, do the following:
· Reduce the number of print pages such as splitting the print data.
· Increase free memory space by deleting unnecessary data in the RAM disk.
As for the RAM disk:
When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory.
Whenyou are ready to print the job, you must go to the printer and use theoperator panel menus to identify which job in the memory you want toprint. You can use this function to print a confidential job (SecurePrint), or verify one copy before printing additional copies (ProofPrint).
NOTE: The printer holds the job until you delete it byusing the operator panel or you turn off the printer. (This is the RAMdisk)
NOTE: Print and Hold functions require a minimum of 320 MBavailable printer memory. Also, you need to configure the RAM disksettings on either the OPERATOR PANEL OR THE PRINTER DRIVER.
NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs.
RAM disk is an option for that printer, but most users do not have thatoption, and if you accessed the menu for the 3100 on most of themachines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not meanthat your computer is communicating with the printer. In Fact, thatmessage would show up even if you did not have it attached to anycomputer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the"reports" menu. Select either the printer settings, or the PCL Fontsreport. When selected, the printer should print which ever report youselected.
One thing you may want to check is to see if there are any print jobs "locked up " in the print spooler on your computer, and also make surethat the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job thathad a problem and is "stuck". This will prevent any job sent after thatto be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clickingon "printer" from the menu and ensure that work offline is not checked.
Take this link and print it out. It will help you later when you get "other" error messages.
http://support.dell.com/support/edocs/sy...
Sep 18, 2009 | Dell Office Equipment & Supplies
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Jan 19, 2008 | HP LaserJet 1300 Printer
Network connections to Lexmark T640 Laser Printer
Might try going into the printer setup on each computer and set it to print after the current job is finished. Let me know :-)
Sep 14, 2007 | Lexmark T640 Laser Printer
Xerox WorkCentre M20i All-In-One Laser Printer Logo
2,931 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
