Question about HP LaserJet 1018 Printer
Printer spooler servics is not working - HP LaserJet 1018 Printer
    President:
  • HP Master
  • 2,022 Answers
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Nov 09, 2010
Print spooler not working
If your OS is windows 7, Click start, on the search bar type services, Pick the services and scroll down to Pinter spooler. Confirm that the spooler is started. if it is not right click the printer spooler service and start it. Else reinstall the printer driver.
Nov 23, 2011 | Dell Dimension E520 PC Desktop
While installing my printer driver the warning appears that your printer spooler is not working
You need to go into services and enable the print spooler.
How to start or stop the print spooler?
  1. Right click on My Computer (Computer on Vista) and select Manage
  2. In the console that opens, pull down the Services menu and applications
  3. Click on Services
  4. Double-click on the Print Spooler key
  5. In the "General" tab, go to Startup Type
  6. Set the value to Automatic, Manual or Disabled
  7. To enable or disable the print spooler service immediately, click Stop or Start
  8. Finally click Apply
Mar 02, 2011 | Computers & Internet
The top of my printer has stopped working?
This error occurs because the Spooler service has not been started or has stopped working. This article helps you fix the problem.This error occurs because the Spooler service has not been started or has stopped working. This article helps you fix the problem.
  1. Click Start, and then click Control Panel.
  2. Double-click Administrative Tools, and then click Services.
  3. Double-click the Printer Spooler service, and then change the startup type to Automatic. This sets the Spooler service to start automatically when you restart the computer.
  4. If you want to start the spooler service immediately, click Start under the Service Status field.
Jan 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Printer is not working.
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance – Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance – Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and select Properties.
In the properties box that open the service status should read “Started” if not click on start.
If it says the spooler is started click stop, wait till the spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
Mar 15, 2009 | HP DeskJet 3745 Printer
Printer Spooler service!
This will provide you with the most common default settings.
  1. Restart (reboot) your system [to assure a clean reinitialized starting point].
  2. Log on as any Windows user that has 'administrator' privileges.
  3. Open your 'Services' console [Start button > Run... > type "services.msc" (without quotes), then hit 'Enter'].
  4. Locate, then open "Print Spooler" [double-click it OR right-click it, then choose "Properties" from the context menu].
  5. Modify the settings on the "General", "Log On", and "Recovery" tabs according to the following images.
"Today's the best day of my life...and NOW you're part of it!"
Dec 11, 2008 | Lexmark E120 Laser Printer
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
49 people viewed this question
Clive
Clive
